Hall effect -- calculate carrier mobility and density
The discussion focuses on calculating carrier density and mobility using the Hall effect in a metallic film. The user applies the formula for Hall voltage, V_H = IB/(tne), and seeks confirmation on their approach to differentiate V_H with respect to the magnetic field B. They calculate the carrier density n using the equation n = I/(e(dV_H/dB)), incorporating the given values. A participant points out that the user initially overlooked including the film's thickness in their calculations. The conversation emphasizes the importance of correctly applying formulas and considering all variables in the calculations.
Kara386
A metallic film has length L=10mm, width W=1mm and thickness t=1##\mu m##. The current is parallel to the long edge and has magnitude ##I=0.7A##. Longitudinal voltage is ##V=1V## and it doesn't change with magnetic field. The Hall (transverse) voltage ##V_H## increases at ##0.3mV/T##. What is the carrier density and what is the carrier mobility?
I'd just like to check what I've done. Not sure whether I have to change something else if I want to infinitesimalise variables, but since all variables but the ones I'm changing are constant I think it's ok.
##V_H = \frac{IB}{tne}##
Where ##n## is charge carrier density. Then I think
##\frac{dV_H}{dB} = \frac{I}{ne}##
That's the step I'm not 100% sure about. If it's ok, then
##n = \frac{I}{e\frac{dV_H}{dB}} = \frac{0.7A}{1.6\times10^{-19} C \times 0.3\times 10^{-3}VT^{-1}}##
Is that right? After that I can just get the mobility ##\mu## from this equation:
##V = \frac{L}{W} \frac{I}{en\mu}##
Thanks for any help!
You forgot the thickness t.
Likes Kara386
I did. Thank you!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
