Harmonic function squared and mean value
The discussion revolves around proving that for a harmonic function u in a disk K, the inequality |u(x,y)| ≤ (1/(a-√(x²+y²))) * (M/π)^(1/2) holds for all points (x,y) in K, given that the integral of u squared is finite. Participants express confusion over the application of the mean value property for harmonic functions since u squared is not harmonic. Suggestions include using the mean value theorem for multiple integrals to establish bounds, despite the challenges posed by the non-harmonic nature of u squared. The conversation highlights the need for careful integration over appropriate regions within the disk to derive the desired result. Ultimately, the problem emphasizes the interplay between harmonic functions and integral inequalities.
arestes
Let u be a harmonic function in the open disk K centered at the origin with radius a. and
∫_K[u(x,y)]^2 dxdy = M < ∞. Prove that
|u(x,y)| \le \frac{1}{a-\sqrt{x^2+y^2}}\left( \frac{M}{\pi}\right)^{1/2} for all (x,y) in K.
Mean value property for harmonic functions.
I first thought this was easy and directly applied the mean property for harmonic functions, but of course, the square of a harmonic function is not harmonic (unless it's a constant).
I can see this problems begs for the mean value using a ball with radius a-\sqrt{x^2+y^2} which would be entirely inside the disk K but I can't get around the fact that u squared is not harmonic. Help please
Are you integrating over the whole disk K (i.e. a double integral) or as a line integral around the boundary of K.
I integrated over the area of the smaller circle inside with radius r=a-\sqrt{x^2+y^2}. This is exactly what I did (I know it's wrong):
u^2(x,y)=\frac{\int_{B_r(x,y)} u^2(w, z)dwdz}{\pi r^2}\leq \frac{\int_K u^2(w, z)dwdz}{\pi r^2}=\frac{M}{\pi r^2}\\<br /> |u(x,y)|\leq \sqrt{\frac{M}{\pi r^2}}
But of course, this would work if u^2 were harmonic, which is seldom the case.
Any ideas? I was thinking maybe applying the maximum principle and somehow get bounds...
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 27 ·
