Harmonic motion of four meter sticks
The discussion focuses on the calculation of the period of harmonic motion for four meter sticks with a mass of 0.1 kg each. The moment of inertia around the center is determined to be (4m*L^2)/3, while the moment of inertia around the pin is calculated as (10m*L^2)/3, resulting in a value of 0.33 kg*m². The correct period of oscillation is established as 2.17 seconds after correcting initial miscalculations that suggested a period of 4.35 seconds.
  • Understanding of rotational inertia and its formulas
  • Basic knowledge of harmonic motion principles
  • Familiarity with gravitational force calculations
  • Proficiency in algebraic manipulation of equations
  • Study the derivation of moment of inertia for various shapes
  • Explore the principles of simple harmonic motion in depth
  • Learn about the effects of mass distribution on oscillation periods
  • Investigate the use of Python or MATLAB for simulating harmonic motion
Physics students, mechanical engineers, and educators looking to deepen their understanding of harmonic motion and rotational dynamics.
ac7597
Bob creates a square frame by connecting four metersticks, each of mass m=0.1 kg, at their ends. He drills a hole at one corner, then suspends the square by a pin through that corner. The square hangs down motionless, so it looks like a diamond.
What is the moment of inertia of the square frame around the pin?
How far below the pin is the center of mass of the square?
Bob pulls the bottom of the frame to the side a short distance, then releases it. The square frame oscillates back and forth, back and forth. What is the period of the motion?
angular velocity = (m*g*d/inertia)^1/2 = 2pi/period
inertia of center = [(1/12) m*L^2 + m(L/2)^2]*4
inertia of center = (4m*L^2)/ 3
inertia around pin = (4m*L^2)/ 3 + 4m(L/ 2^(1/2) )^2
inertia around pin = (10m*L^2)/ 3
inertia around pin = (10*0.1*1^2)/ 3 = 0.33 kg*m^2
d= 1/2^(1/2) = 0.707m
(0.1*9.8*0.707/0.33)^1/2 = 2pi/period
period=4.35 seconds
Apparently 4.35s is not the right answer. I don't know why.
ac7597 said:
0.1*9.8*0.707
(4*0.1*9.8*0.707/0.33)^1/2 = 2pi/period
period=2.17 seconds
That's correct
  • · Replies 20 ·
