Has the current through battery 1 changed?
  • Thread starter Thread starter cy19861126
    Battery Current
The discussion focuses on analyzing the electrical characteristics of two circuits containing bulbs and boxes with unknown resistances. It concludes that the resistance of box A is less than that of box B, as indicated by the increased brightness of bulb 2 when the boxes are interchanged. The voltage across the battery can be expressed as V(Bat) = (V(Box A) + V(Bulb 1))/2 for circuit A and V(Bat) = V(Box B) + V(Bulb 2) for circuit B. The relationship between voltage, current, and resistance is established through Ohm's Law (V = IR) and the discussion of power equations.
  • Understanding of Ohm's Law (V = IR)
  • Knowledge of series and parallel circuit configurations
  • Familiarity with electrical power equations (P = IV, P = I²R, P = V²/R)
  • Basic concepts of resistance and brightness in electrical circuits
  • Explore the implications of changing resistances in parallel circuits
  • Learn about the effects of resistance on current and voltage in series circuits
  • Investigate the relationship between power, current, and voltage in electrical systems
  • Study practical applications of Ohm's Law in real-world electrical circuits
Students and educators in physics or electrical engineering, electrical technicians, and anyone interested in understanding circuit behavior and the relationship between voltage, current, and resistance.
cy19861126
In this problem, box A and box B contain unknown combinations of light buls. Bulb 1 is identical to bulb 2. The batteries are ideal.
1. a) In the circuit A (see first attached pic) the voltage across bulb 1 and the voltage across box A are equal. What, if anything can you say about the resistance of box A compared to the resistance of bulb 1. Explain
b) Write an expression for the voltage across the battery, V(Bat), in terms of the voltage readings across box A and across the bulb V(Box A), V (Bulb 1)
2. a) In the circuit B (see second attached pic) the voltage across bulb 2 and the voltage across box B were find to be equal. What, if anything, can you say about the resistance of Box B compared to the resistance of bulb 2?
b) Write an expression for the voltage across the battery V(Bat) in terms of the voltage readings across box B and across the bulb V(Box B) V (Bulb 2)?
3. Box A and box B are now interchanged. It is observed that bulb 2 is now brighter than it was when box B was in that circuit
a). Is the resistance of box A greater than, less than, or equal tot he resistance of box B?
b) Has the current through battery 1 changed? If so, how?
c) Has the current through battery 2 changed? If so how?
V = IR
Series: Req = R1 + R2
Parallel: Req = 1/R1 + 1/R2
1. a)Nothing. Without current given, we pretty much cannot tell which resistance is higher.
b) V(Bat) = (V(BoxA)+V(bulb1))/2
2. a) The resistance are the same
b) V(Bat) = B(Box B) + V(Bulb 2)
3. a) Less than. Brighter bulb means more current and less resistance
b) Yes, more current
c) Yes, less current
PS: It seems like I have no problem in determining current and resistance from the given information, but a huge problem in determining voltage. Please provide some clue to this problem. Many thanks~~
Well the voltage in the first circuit would be the same as the source voltage because all components are in parallel. So that's no problem.
As for the second circuit series circuit, if you have equal resistances, then the voltage is shared equally by the bulbs, which you already stated. However upon changing boxes, you find the brightness of the bulb increases. This means that the current increases in the circuit. So given the equation V = IR, does that help in anyway to give you an idea about the change in voltage? Remember that the current increased due to increased brightness, therefore for the bulb, we have more current flowing through it which gives it a...?
From your statement, it seems that voltage and current are directly related. Increasing the current increases the voltage by using the equation, V = IR. However, there is also this other equation P = IV. This equation shows you that current and voltage are inversely related. How can this be so?
Indeed, voltage is proportional to current as given by V = IR. When you consider the case that you've asked, it is true that V = P/I. But power can be either IV, I2R, or V2/R. So if we can say
V=P/I = (IV)/I = V
V = (I2R)/I = IR = V
V = (V2/R)/I = V2/(IR) = V2/V = V
You will find the same is true for current. What I'm getting at here is that we can't have power without a combination or V,I, or R. And no matter what the combination, we get V = V which is the same as V = IR, so we come back to the direct relation of V and I.
