Has the current through battery 1 changed?
  • Thread starter Thread starter cy19861126
    Battery Current
This discussion revolves around a circuit problem involving two boxes containing light bulbs and their respective resistances. The original poster examines the relationship between voltage, current, and resistance in both circuits A and B, particularly focusing on how interchanging the boxes affects the brightness of the bulbs and the current through the batteries.
  • Participants explore the implications of voltage and resistance in parallel and series circuits. Questions arise regarding the relationship between current and voltage, especially when the brightness of the bulbs changes. Some participants attempt to clarify how the equations V = IR and P = IV relate to the observed changes in the circuit.
The discussion is active, with participants providing insights and questioning the relationships between voltage, current, and resistance. There is an exploration of how the changes in the circuit setup affect the current and voltage readings, though no consensus has been reached on the implications of these changes.
Participants note the challenge of determining voltage from the given information, which may be influencing their reasoning. The discussion also highlights the complexity of interpreting the effects of interchanging the boxes on the circuit behavior.
cy19861126
In this problem, box A and box B contain unknown combinations of light buls. Bulb 1 is identical to bulb 2. The batteries are ideal.
1. a) In the circuit A (see first attached pic) the voltage across bulb 1 and the voltage across box A are equal. What, if anything can you say about the resistance of box A compared to the resistance of bulb 1. Explain
b) Write an expression for the voltage across the battery, V(Bat), in terms of the voltage readings across box A and across the bulb V(Box A), V (Bulb 1)
2. a) In the circuit B (see second attached pic) the voltage across bulb 2 and the voltage across box B were find to be equal. What, if anything, can you say about the resistance of Box B compared to the resistance of bulb 2?
b) Write an expression for the voltage across the battery V(Bat) in terms of the voltage readings across box B and across the bulb V(Box B) V (Bulb 2)?
3. Box A and box B are now interchanged. It is observed that bulb 2 is now brighter than it was when box B was in that circuit
a). Is the resistance of box A greater than, less than, or equal tot he resistance of box B?
b) Has the current through battery 1 changed? If so, how?
c) Has the current through battery 2 changed? If so how?
V = IR
Series: Req = R1 + R2
Parallel: Req = 1/R1 + 1/R2
1. a)Nothing. Without current given, we pretty much cannot tell which resistance is higher.
b) V(Bat) = (V(BoxA)+V(bulb1))/2
2. a) The resistance are the same
b) V(Bat) = B(Box B) + V(Bulb 2)
3. a) Less than. Brighter bulb means more current and less resistance
b) Yes, more current
c) Yes, less current
PS: It seems like I have no problem in determining current and resistance from the given information, but a huge problem in determining voltage. Please provide some clue to this problem. Many thanks~~
Well the voltage in the first circuit would be the same as the source voltage because all components are in parallel. So that's no problem.
As for the second circuit series circuit, if you have equal resistances, then the voltage is shared equally by the bulbs, which you already stated. However upon changing boxes, you find the brightness of the bulb increases. This means that the current increases in the circuit. So given the equation V = IR, does that help in anyway to give you an idea about the change in voltage? Remember that the current increased due to increased brightness, therefore for the bulb, we have more current flowing through it which gives it a...?
From your statement, it seems that voltage and current are directly related. Increasing the current increases the voltage by using the equation, V = IR. However, there is also this other equation P = IV. This equation shows you that current and voltage are inversely related. How can this be so?
Indeed, voltage is proportional to current as given by V = IR. When you consider the case that you've asked, it is true that V = P/I. But power can be either IV, I2R, or V2/R. So if we can say
V=P/I = (IV)/I = V
V = (I2R)/I = IR = V
V = (V2/R)/I = V2/(IR) = V2/V = V
You will find the same is true for current. What I'm getting at here is that we can't have power without a combination or V,I, or R. And no matter what the combination, we get V = V which is the same as V = IR, so we come back to the direct relation of V and I.
