ApplePion
- 190
OK, thanks, Vanadium.
ApplePion said:So how do we know that the new particle is not a combination of a very heavy newly encountered quark and its anti-partner?
mfb said:- It would have a mass of ~63 GeV, and therefore have been within the range of LEP (as the process e- e+ -> q anti-quark is quite likely, if the energy allows it) and Tevatron.
I don't really understand these answers given to Applepion.Vanadium 50 said:Reason two: A 65 GeV quark would completely screw up precision electroweak measurements and would have been discovered indirectly years ago.
Interesting question. In condensed matter physics these quasi-particles are never elementary, so I guess simply for the mass generetion there's no need for the Higgs to be elementary.TrickyDicky said:In view of all this I'd like to reiterate my question, does the SM Higgs boson have to be an elementary particle or it could be a composite boson and still be an SM Higgs?
Right, and the analogy is quite justified since the Higgs mechanism was actually an analogy about superconductivity and condensates since the initial idea by Higgs, Englert, Brout and Kibble but applied to the vacuum instead of condensed matter.tom.stoer said:Interesting question. In condensed matter physics these quasi-particles are never elementary, so I guess simply for the mass generetion there's no need for the Higgs to be elementary.
The binding energy is related to the QCD energy scale, which is ~250MeV. Pions have less, light baryons have more, but it does not increase with the quark masses. For heavy hadrons, the mass is basically the mass of the quarks, excited states may have some hundred MeV more.TrickyDicky said:Why would the quarks in that putative new boson particle have to be that heavy and therefore not any of the six SM ones? As I understand it the fact that the mass of the new particle is around 125 GeV doesn't imply that in case it was a composite boson its individual quarks have to add up to 125 GeV, just like in a proton its three quarks individual mass terms don't add up close to 1 GeV, only around a 1% of that.
I am sure LEP looked at it and Tevatron checked it. I know that both ATLAS and CMS are searching for a 4th generation in the full observable mass range, and the lower limits are at least some hundred GeV (probably more than 1 TeV now).ApplePion said:mfb: "Or the 7th quark with up, down, strange and (rare) charm and bottom. None of these combinations was observed"
Have those mass ranges been examined thoroughly?
It is the other way round: The decay of spin1-particles (here: 3S1) to e- e+ or mu+ mu- can occur via the electromagnetic interaction (q anti-q -> photon -> lepton antilepton).ApplePion said:The 3S1 decays you refer to are weak force decays, right? The two-photon decay of the putative 1S0 state is an electromagnetic force decay, right?
Parlyne said:It's worth noting that if there is a fourth generation, its neutrinos cannot be light. Measurements of the width of the Z make it quite clear that there's only room for 3 light neutral fermion states in Z decays. This means that any new generation of fermions must have neutrinos heavier than ~45 GeV.
eXorikos said:Unitarity of the CKM matrix also indicates a maximum of 3 generations.
Vanadium 50 said:It doesn't, and indeed, it cannot. Non-unitarity of the 3x3 CKM can require a 4th generation, but unitarity cannot forbid one.
As said: "It doesn't, and indeed, it cannot. Non-unitarity of the 3x3 CKM can require a 4th generation, but unitarity cannot forbid one."eXorikos said:... but why does unitarity not prove the impossibility of a fourth generation?
If the CKM matrix is unitary, how can there be a fourth generation that mixes with the three known generations?
