Having trouble understanding why FTL implies time travel
155 replies · 24K views
neopolitan said:
Since v>c the equation here would end up being imaginary as well.
If you assume the equation E = m0 * 1 / sqroot (1 - v²/c²) * c² works for tachyons, then if their rest mass was imaginary this would give a real value for energy. See this article for a discussion.
neopolitan said:
Unless we find that our equations are only locally applicable, and reflections of a higher level of theory which incorporates FTL without violating causality or the local applicability of relativity, then I suggest we just leave tachyons as imaginary in their entirety.
Do you disagree that some equations of relativity that work for sublight particles already give nonsensical answers when we plug in v=c, including the one above? If so, it makes no sense to argue that tachyons are incompatible with SR on the basis of equations breaking down, unless you are also willing to argue that photons are incompatible with SR for the same reason.
neopolitan said:
Some of the arguments to leave the door open to tachyons seem to border on messianic.
Um, they are merely theoretical arguments about what the logical consequences of the theory of SR--it's just an objective fact that there is nothing in the theory of SR that would absolutely rule out tachyons. No one is actually saying tachyons are remotely plausible in the real world! The point is that your arguments against tachyons show a misunderstanding of the theory of SR on your part, which is the only reason people are arguing with you, not because they want to convince you that you should believe tachyons have a non-negligible likelihood of actually existing.
neopolitan said:
However, this thread was about why FTL implies time travel. I tried to address that but am being dragged off course into arguments about a particle I don't think exists.
Come again?? How can you possibly discuss the theoretical question of whether FTL implies time travel if you refuse to even discuss the hypothetical that FTL is possible? We don't need to believe that FTL is possible in the real world to deduce what the theoretical consequences would be if FTL were possible. And one of those theoretical consequences is that if the two postulates of SR remain valid in a universe where FTL is possible, then logically this implies the possibility of time travel in such a universe. That theoretical consequence is what this thread is all about!
Repeating for Jesse's benefit:
neopolitan said:
Some of the arguments to leave the door open to tachyons seem to border on messianic. If you want to have faith in tachyons, that's all well and good, but I think such faith is as helpful in mainstream physics as intelligent design is in the field of biology.
I'll be happy to retract that statement if tachyons are required to explain phenomena which can't otherwise be explained by the standard models. (Note that I do not accept that a theory may require tachyons as sufficient (and even less the weaker "permit tachyons"), since the stronger comment indicates to me that the theory in question may be incomplete. Explanations of phenomena only, not wriggle room for popular theories.)
However, this thread was about why FTL implies time travel. I tried to address that but am being dragged off course into arguments about a particle I don't think exists. So, if nothing arises to persuade me there is any value in continuing to invest time in considering this highly unlikely particle, I will be bowing out.
Perhaps I wasn't being entirely clear. I would see value if and only if tachyons are required to explain phenomena which can't otherwise be explained by standard models. Otherwise the discussion seems to be based on no more than wishful thinking.
I'll keep an eye on the thread, but until that condition is met, I won't be involving myself deeply in any tachyon discussion.
cheers,
neopolitan
PS About the imaginary energy, I was assuming m0 was more a magnitude (with mass units, rather than imaginary mass units). If m0 is imaginary, then you end up with two imaginary numbers multiplying and that results in negative energy. Perhaps you could use tachyons to power your perpetual motion machine. Of course, I think that the perpetual motion machine is imaginary as well, so I imagine that using imaginary tachyons with imaginary mass would be totally appropriate.
Tachyons are the only form of FTL I know of that are compatible with SR (obviously you can't have things like wormholes in SR because they involve curved spacetime, and in any case wormholes lead to the same sorts of problems with causality in GR). Would you say it's not worth discussing the theoretical consequences of FTL in general? If so, why did you bother posting on this thread, which is specifically about the question of what consequences FTL would have for causality in a relativistic universe?
And please stop using phrases like "wishful thinking" when I've made it clear I don't believe in tachyons, and I assume the same is true for other participants on this thread. In a theoretical discussion you can discuss anything that isn't specifically forbidden by the theory in question, even possibilities that you don't think are remotely plausible in real life. Theoretical physicists do this sort of thing all the time to test the limits of existing theories (it's especially common in GR which allows for a lot of very weird spacetimes).
No, [tex]\sqrt{1 - v^2/c^2}[/tex] is the denominator so you'd have an imaginary rest mass divided by an imaginary number, so the energy would be a positive real number.
Even if negative energy were possible it would not lead to any violations of conservation of energy, which is what is normally meant by "perpetual motion machine". Note that unlike the implausible but theoretically possible tachyons, negative energy is a theoretical possibility that many physicists think there is actually experimental evidence for, in the form of the Casimir effect in quantum physics.
JesseM said:
No, sqrt{1 - v^2/c^2} is the denominator so you'd have an imaginary rest mass divided by an imaginary number, so the energy would be a positive real number.
JesseM,
Read your own link - http://math.ucr.edu/home/baez/physics/ParticleAndNuclear/tachyons.html"
JesseM's link said:
Now another familiar relativistic equation is E = m*[1-(v/c)2]-1/2. Tachyons (if they exist) have v > c. This means that E is imaginary! Well, what if we take the rest mass m, and take it to be imaginary? Then E is negative real
You could be right and he is wrong. In which case you need to let him know, since the remainder of the article is pretty much based on negative energy. But if that is the case, I suggest you don't tell us all to go off reading incorrect articles.
I want to bow out but I don't want to rudely ignore you, nor let these sort of inconsistencies stand uncorrected. I'll accept whatever corrective action you think is necessary and be on my way.
cheers,
neopolitan
It's definitely true that a positive imaginary number (i.e. x*i where x is a positive real number) divided by a positive imaginary number gives a positive real number, I hope you wouldn't dispute this...perhaps the author of the page was assuming that the rest mass was a negative imaginary number, in which case the statement about energy being negative would be correct. I don't know what the motivation for that would be though. The wikipedia article on tachyons says here that the "Feinberg reinterpretation principle" tells us that "a negative-energy tachyon sent back in time in an attempt to violate causality can always be reinterpreted as a positive-energy tachyon traveling forward in time", which would seem to suggest the rest mass of a tachyon can be treated as either a negative or positive imaginary number.
Also, I don't know what you mean when you say "the remainder of the article is pretty much based on negative energy"--for example, the conclusion in the next paragraph that "they accelerate (p goes up) if they lose energy (E goes down)" will still be true if you assume a positive imaginary rest mass such that both E and p are positive (see the fifth paragraph here for an explanation). Nor do any of the other subsequent statements seem to depend on the idea that E and p are negative.
neopolitan said:
I don't think you can have FTL. But what I am saying is that if in the real universe you could (since what I think has little bearing on what the universe will permit), then I think we would find that that FTL would not lead to causality violations.
Yes, of course. (DaleSpam's thoughts about this are the same as mine). But that's not what you were saying before. At least you didn't make it clear that that's what you meant. You just jumped into a discussion about how SR+FTL implies "time travel" (in the sense that you can receive the answer to a question before you send the question), and claimed that the conclusion is wrong.
neopolitan said:
Tachyons that don't have their own inertial rest frame is a cop-out. Even if they don't, it's suddenly not SR (which I don't think we would disagree about).
This is very very wrong. A tachyon in SR is just a spacelike curve in Minkowski space, i.e. a curve such that its tangent has a slope <1 everywhere in an inertial frame.
neopolitan said:
I am not convinced that you would have GR either, but certainly any equation with sqrt(1-v2/c2) would be looking very dodgy.
The gamma factor appears in equations that describe how something changes from one inertial frame to another, and the v is the velocity of one of the frames in the other. So if there are tachyons in SR, you still won't ever have a reason to input a v>c in such a formula.
neopolitan said:
FTL doesn't have to mean that "emission/detection time doesn't grow linearly with the distance the message travels".
In the framework of SR it does. It's the only way to avoid logical inconsistencies.
neopolitan said:
But sure, if you had instantaneous translation, or negative "time growth" (which I assume is stuff going back in time), then you do get causality violations. I don't see the relevance, but I agree with you.
Now I have no idea what you're talking about. Those things that you don't see the relevance of are what this thread is about.
Fredrik-----------
If you apply the additon of velocities formula isn't that indirectly inputting a v>c.
That the equation is basically the Lorentz transformation applied to Gallilean coordinate transforms and in the process of deriving the simplified formula the gamma factor was necessarily applied. This would seem to imply that directly deriving additive velocities through first principles would mean entering v>c into this equation [sqrt(1-v2/c2)]
Would you agree?
Or do you think this is not a problem because the (i's) might cancel out. Two imaginary velocities added together result in one meaningful , real velocity?
Fredrik ----
Two questions
1) Do you not think that this whole procedure, not to mention this whole discussion is already filled with logical inconsistancies?
2) What kind of scientific rationale is that ?? We should assume this result must be correct because otherwise we have logical inconsistancies,,, rather than logical inconsistancies might possibly indicate erroneous assumptions that should be questioned??
JesseM;2048616]Tachyons are the only form of FTL I know of that are compatible with SR
Does this mean that you do not consider ,possible EPR transmission as being FTL , or that you don't consider it compatible with SR??
In either case ,why?
DaleSpam said:
This is fine. I also would tend to pick causality over relativity if FTL were unavoidable and I were given the choice.
Why do you feel that it would be a question of "choosing" one or the other if it was simply a matter of a small addition to SR.
Do you think its "OH well , we found an exception , I quess we just have to throw out SR"
Do you think it is "Impossible" that empirical discoveries in QM or cosmology might necessitate some kind of revision or expansion in just about any field of physics you can name.
Right now there are question regarding Conservation of m and E:
virtual particles and "dark" energy.
Causality: FTL is not the only assault being mounted. There are several theories and even apparent evidence in QM [delayed choice etc] that would seem to indicate the possibility that reverse causality might not only be possible but actually a fundamental reality of particle and photon interaction.
Gravity: Galactic angular mometum anomalies etc. seem to present the choice of a possible extension of GR to cover cosmic scale or a completely new form of matter [Ptolomeic epi-matter] so to speak.
I want to make it clear I am not promoting any of these possibilities, only pointing out that it is not a particularly good time to have any expectations that our current theories are the "last" word/
It's been proven that EPR effects cannot be used for FTL communication according to orthodox QM, but sure, I suppose you could imagine a universe where SR is true but QM is modified in such a way that entanglement can be used for FTL communication. In this case all the same arguments about it leading to a breakdown in causality would apply--all that's important is that there's a spacelike separation between the transmission event and the reception event for an FTL signal. If you'd answer my questions in post #88 perhaps we could make some progress in understanding exactly which part of the logic you disagree with.
What "addition" would that be? As always, SR is defined by the two postulates, and there's no way to have FTL signaling without causality violation unless one of those postulates is violated.
I was actually referring to the principle of relativity rather than SR. If FTL and causality then the equations describing the behavior of tachyons would necessarily have different forms in different inertial reference frames. This means that the principle of relativity is wrong.
Now, of course, there are mountains of evidence supporting SR, the Lorentz transforms, time dilation, etc., and the discovery of tachyons wouldn't negate a single piece of that evidence. Similarly, when SR was invented that did not erase Newtonian mechanics nor any of the evidence supporting it. What would happen is that we would place some currently unknown limit on the domain of applicability of the results of SR, just like SR placed a previously unknown limit (v<<c) on the domain of applicability of Newtonian mechanics. We wouldn't get rid of it (since we have so much evidence supporting it), but we would use it only where it applies and it would certainly not apply to causal tachyons.
I certainly don't think that our current theories are the "last" word, and in fact I would be highly disappointed if they were.
neopolitan said:
ITachyons that don't have their own inertial rest frame is a cop-out. Even if they don't, it's suddenly not SR (which I don't think we would disagree about).
Hi neopolitan,
Sorry to interject, but don't forget that the time coordinate in SR inertial frames is defined by using the Einstein synchronization procedure on inertially moving clocks at rest wrt each other. Now, suppose that in some inertial frame you had two clocks separated by a fixed distance and traveling at some [tex]v\geq c[/tex], could you use the Einstein synchronization procedure to synchronize them? If not, then their rest frame is not a SR inertial frame.
This will be my last comment on this thread, but it is worth pointing out where this medium seems to fail so regularly.
I didn't jump into an on-going discussion.
I specifically addressed the OP's original question, I even quoted it to highlight that I was responding solely to that question, and I ignored the rest of the discussion. I freely admit that I didn't read any of the discussion between the OP's question and my first post to the thread.
I do wonder what the OP thinks of the consequences of his rather innocent post.
To Dale: Even if that is the case (re Einstein synchronisation) then it really doesn't prove anything to me. To me the logic seems to go like this: tachyons do something impossible by going faster than light, by virtue of doing this impossible thing you can't synchronise them using Einstein synchronisation, since they can't be thus synchronised they don't have their own inertial rest frames, since they don't have their own inertial rest frames they don't have to accord with the postulates of SR, therefore SR has no dominion and can't be use to prove that tachyons don't exist, therefore they might be possible. It's akin to saying that SR can't be used to prove that god does not exist, since any god would be outside the scope of SR, therefore god exists.
I'm even willing to accept that the imaginary tachyons don't have an inertial rest frame. I just can't see how they fall under the category of SR.
It goes back to what I think you said in the second last post: if tachyons did exist then SR would be a subordinate theory to a greater one which also covers those things which can travel at v>c and so if we are talking tachyons then, strictly speaking, we are no longer talking SR.
My apologies if I've misinterpreted you.
Bed calls. I've answered everyone, I don't intend to respond anymore and I won't be monitoring the thread either.
cheers,
neopolitan
If tachyons have an imaginary mass / the imaginary 'boost factor', of course they'll cancel out, giving a positive energy, quite simple maths I can't see why anyone would dispute that, so calling it 'dodgey' as an argument is invalid. The beauty of the equations done by Einstein is their amazing nature to hold in all situations (looked at so far) and it can also in theory hold for tachyons if they have an imaginary mass
I also don't see neopolitan why you want to continue talking about FTL (you don't seem to mind) and yet you have an aversion to talking about a particle which is the closest thing we have to (and basically embody) the concept?
Also, it's my understanding that it is possible to use the e = m0 gamma c2 formula for photons & tachyons however it becomes redundant due to the nature of the calculations, therefore it's far more constructive to use clear & defined inertial frames!
No. Look at my previous reply to you (included below for completeness). If u, v and w are defined as in that post, the derivation of the velocity addition formula goes like this:
The slope of the tachyon's world line is 1/v in F' and 1/w in F. That means that the Lorentz transformation
[tex]\gamma\begin{pmatrix}1 & u\\ u & 1\end{pmatrix}[/tex]
must take [tex]\begin{pmatrix}1\\ v\end{pmatrix}[/tex] to a vector proportional to [tex]\begin{pmatrix}1\\ w\end{pmatrix}[/tex]. That's all we need to find w:
[tex]\gamma\begin{pmatrix}1 & u\\ u & 1\end{pmatrix}\begin{pmatrix}1\\ v\end{pmatrix} =\gamma\begin{pmatrix}1+uv \\ u+v\end{pmatrix} =\gamma(1+uv)\begin{pmatrix}1 \\ \frac{u+v}{1+uv}\end{pmatrix}[/tex]
So w must be what I said before:
Fredrik said:
I'm not really sure what you're asking. I assume that we're talking about the formula that says that if the velocity of frame F' in frame F is u and the velocity of a particle in frame F' is v, then the velocity of that particle in frame F is
[tex]w=\frac{u+v}{1+uv}[/tex]
What exactly are you asking? Which of these variables (u,v and w) do you want to make bigger, and which one(s) do you think will be smaller as a consequence? (Note that by definition we have u<1, but if the particle is a tachyon, both v and w will be >1).
No. That doesn't even make sense. Lorentz and Gallilean transformations have one thing in common: they both represent a coordinate change from one inertial frame to another, but the term "inertial frame" doesn't mean the same thing in those two contexts.
Would you agree?
No. See above.
1. No.
2. I have no idea what you're talking about. Who says we have to assume that something is correct? As for your last question, you're missing the point, again. You won't find that logical inconsistency unless you take SR+FTL+"short emission/detection times" as the starting point. When you've found the inconsistency, you have learned something, which is that a theory that includes all of those doesn't make sense. You're right that there's more than one assumption that we might consider replacing, but the only way to realize that is to do the very thing that you're objecting against. So I really have no idea what you're complaining about. I just said that in the framework of SR, the possibility of FTL messages implies that emission/detection times grows at least linearly with distance. It makes no sense to object against that unless you think the words mean something different than what they actually mean.
They do because you can define spacelike curves in Minkowski space. (Curves with slope <1 in an inertial frame). That's really all there is to it, since SR is the theory that uses Minkowski space as a model of space and time.
Photons fall under SR and do not have an inertial rest frame. Accelerating objects also fall under SR and do not have inertial rest frames.
Almost, I would just specify that we are talking about tachyons which do not violate causality. "if causal tachyons did exist then SR would be a subordinate theory to a greater one which also covers those things which can travel at v>c and so if we are talking causal tachyons then, strictly speaking, we are no longer talking SR". It is only causal tachyons that violate relativity.
You could theoretically have tachyons that are perfectly compatible with relativity. But relativistic tachyons would violate causality.
=JesseM;2041873]I'll try to address the rest later, but just wanted to quickly post on what I think is the heart of the matter:
So, question #1, do you agree that "any event can be assigned time and space coordinates in any inertial frame"?
In principle I would [and have] agree
I agree that any event that could possibly occur would have coordinates.
The question of assigning specific coordinates to hypothetical events is the question I am posing.
If the answer here is yes, then I assume this should apply to both the event of the tachyon being sent and the event of the tachyon being received (no need to comment on this unless you disagree). In this case, my question #2 is, would you also agree that the premise "FTL" implies that there must be at least one inertial frame where the difference in space coordinates dx between these two events is larger than the difference in time coordinates dt, in units where c=1?
Once again I would [and have] in principle agree completely. But dt<dx is a range of possible coordinates and the methods and logic of assigning a specific quantitative dt is the core of the question.
If you answered yes to questions #1 and #2, then since you also agreed that the coordinates of different inertial frames must be related by the Lorentz transform if SR is correct, question #3 is: do you agree that if we have two events where dx > dt in some frame, it is always possible to find a second inertial frame such that when you do the Lorentz transform to find the coordinates of the same events in the second frame, their order will be reversed in the second frame?
Do you realize these questions are a physics version of the classic "Do you like women , yes or no?" Well , yes
DO you think it is wrong to hit women, yes or no?"
Yes
"If you answered yes to the first two, then have you stopped beating your wife ,,,yes or no?"
Note that I gave an example of this where the events had a dx of 20 and a dt of 10 in the first frame and their order was reversed in the second frame moving at 0.8c relative to the first, but it's possible to prove that in general, if dx > dt for two events in one frame then it must be possible to find a different inertial frame with sufficient velocity relative to the first (a velocity less than c of course, since all inertial frames move at sublight speeds) such that when you plug that v into the Lorentz transformation equations and apply them to the coordinates of the events in the first frame, then the order of the events is reversed in the second frame. This would not be true for events where dx < dt or dx = dt, it's only true when dx > dt.
So, please address my questions 1-3 and perhaps this will help pinpoint exactly where your objection to the logic of the if-then conditional lies.
Through the course of this discussion I think I have come to understand your point of view and can see how, from that perspective , some of what I have been saying would seem "illogical" . I also completely agree that in this situation with many if-conditional premises it is necessary to focus on the center. The premise/argument that
"the events had a dx of 20 and a dt of 10 in the first frame"
This is the focus , both the quantitative value of dt and also the assumption that was the basis of this assigment.
Can I assume that if you had simply assigned a dt=(-10 ) in this premise that you would understand how I would see it as "including the conclusion in the premises" ??
Ie. "assuming a signal from A arrives 10 sec before it was sent in frame B Then "time travel"
AS I understand your point; because the actual assignment dt=10 did not obviously imply time travel and therefore required a transformation between frames to arrive at dt=-10 there was no inclusion of this conclusion in the premises.
OK I can see your point, even if the two times are effectively the same through a simple transform and the only real difference is that by deriving B from A instead of
A from B was ,,that this way it was not directly including the conclusion in the premises.
But in actuality there is reason to see ( dt=10 ) as directly indicating and requiring time travel. That for that dt to occur would mean going back in time 6 sec in frame A
That at t=0 ,x=0 x'=0, t'=0 from the perspective of frame B ( x=20) in A was colocated with x'=12 and had a time of t=16 AS frames always have local agreement and overall agreement this would seem to indicate a time discrepancy at x=20 from 16 --> 10 sec.=(-6)
What is your take on this?
Please do not come back with "the first postulate says that etc etc."
That simply translates to "Well we know that time travel will happen in one frame so it must happen in all frames"
I am talking about an explicit premise IF a tachyon goes back in time 6 sec in frame A THEN time travel and how that would effect the significance of the overall argument.
Beyond the above question is :
The applicability of the addition of velocities equation.
The overall results of the application of the basic assumption to bi-directional assigments and the many questions that arise from those results. Questions of logic, physics and conformity to the first postulate.
I have started to address some of these in the past and will try to find time to get them into a clear form in the near future.
Thanks and sorry for taking so long to directly respond to this post.
DaleSpam said:
Hi neopolitan,
But what if you have an inertial frame A with v< c and tachyons traveling v> c do think that clocks in A could not be synched by the light method using tachyons instead??
Without the a priori assumption of the new implicit Postulate of SR (FTL = time travel.
=DaleSpam;2048839]I was actually referring to the principle of relativity rather than SR. If FTL and causality then the equations describing the behavior of tachyons would necessarily have different forms in different inertial reference frames. This means that the principle of relativity is wrong.
Once again I don't understand. Suppose we eventually found a matrix or some means of determining motion within a system. Do you think this would mean that SR was wrong?
SR doesn't say motion doesn't exist or have any reality ,only that it is right now undetectable and working with this reality derived a system for achieving invariance of physics.
Thank you , my point exactly and I certainly couldn't have put it better or more succinctly
Original post Austin0
Me too.
But you do seem to feel that SR as it now exists should be able to simply and directly apply to phenomena that is not strictly within its domain . SO you think it wouldn't apply to imaginary causal tachyons but would apply to imaginary time traveling tachyons ?
=JesseM;2048835]It's been proven that EPR effects cannot be used for FTL communication according to orthodox QM
I would be interested in sources for this as I haven't encountered it. Any google hints would be appreciated , thanks.
No, clocks could not be synchronized by tachyons any more than they could be synchronized by baseballs or proton beams today. The Einstein synchronization procedure relies on the fact that light has the same speed in all reference frames. Baseballs, protons, and tachyons do not have the same speed in different reference frames.
Austin0 said:
SO you think [SR] wouldn't apply to imaginary causal tachyons but would apply to imaginary time traveling tachyons ?
Yes, exactly.
That doesn't make any sense--the very idea of taking a hypothetical about physics as a premise is to imagine a universe where the hypothetical really occurs and see what consequences would follow in such a universe. If you are imagining a universe where FTL is still purely hypothetical, then you aren't taking FTL as a premise in the first place!
If gave the if-then conditional "if I was standing in the open and it was raining, then I would get wet", would you then disagree since hypothetical rain can't get people wet the way real rain does? Your own statement above appears every bit as senseless.
Again that doesn't make any sense. If we have a general proof that for any set of coordinates that satisfy dx>dt in some inertial frame, there must then be an inertial frame where the events occur in reverse order, then naturally this proof would apply to whatever "specific quantitative dt" and dx you happen to imagine occurring in the hypothetical. Perhaps you are arguing that there would be some difficulty calculating dt in the first place, but that doesn't make sense either--you agreed earlier that in a relativistic universe we should be able to assign x and t coordinates to any event, so that means you can find the t coordinates of the event of the signal being sent and the event of the signal being received, and dt is just the second t coordinate minus the first t coordinate.
Yes
That analogy doesn't make any sense, because there is no logical reason that answering yes to the first two questions would compel you to answer yes to the question about beating your wife. In contrast, I'm just trying to lead you through the inescapable logic of the proof, so I've specifically chosen questions such that if you answer yes to all of them, it becomes obvious that you have no choice but to answer yes to the question of whether the premises of SR and FTL signaling together imply the conclusion of backwards-in-time signaling.
No, that particular value of dt is not the focus. As I said, it is easy to come up with a general mathematical proof that if the coordinates of two events in one frame are such that dx>dt, then it is always possible to come up with a velocity v such that when you use that v in a Lorentz transformation, the order of the two events is reversed in the second frame. Would you like to see this proof, or do you agree that such a general proof is possible?
If you do agree, then it should be easy to see that for any specific choice of coordinates for the transmission-event and the reception-event such that dx>dt--whether (0,0) and (20,10) or (50,70) and (60,79.999) or (-16.5,3000) and (501,3007)--it will be possible to find a different inertial frame where the events happen in reverse order according to t-coordinates assigned by the new frame.
Of course, but it is not obvious that the premise "FTL" is synonymous with the possibility that the reception-event happens before the transmission-event, while it is obvious that FTL should be synonymous with the notion that dx>dt in some inertial frame. Of course the point of the proof is to show that if you take SR as a premise, then the latter "obvious" implication of the premise FTL implies the former "not-so-obvious" implication of the premise FTL. That's the difference between a vacuous tautology and a non-vacuous proof where the conclusion is still logically implied by the premise but it may not be immediately obvious that it follows just by looking at the premises.
Yes, but again, in all mathematical proofs you can show that the conclusion is logically implicit in the premises, but in the case of non-vacuous proofs you have to go through some steps--like the "simple transform" above--to demonstrate this. Incidentally, for a specific choice of coordinates like (0,0) and (20,10) it's true that you just need to apply the transform with a particular choice of velocity to show that they can happen in reverse order in another frame, but it may not be obvious that for any choice of coordinates for the events such that dx>dt, it would always be possible to find a velocity such that when you plug that velocity and those coordinates into the Lorentz transform, the result is that the events happen in reverse order in the new frame. This is why I offered to provide a proof of this claim if you doubt it.
Are you asking where the x=20 marking on A's ruler was at time t'=0 in B's frame? If so, yes, the answer is that it was next to the x'=12 mark on B's ruler, and at the moment the x=20 mark on A's ruler was passing next to the x'=12 mark on B's ruler, the clock attached to the x=20 mark on A's ruler must have read:
t = 1.666... *(0 + 0.8*12) = 16.
So, when you say "this would seem to indicate a time discrepancy at x=20 from from 16 --> 10 sec.=(-6)", are you talking about the time between the moment the clock at x=20 on A's ruler is next to the event of the tachyon signal being received, and the moment the clock at x=20 on A's ruler is next to the x'=12 mark on B's ruler? If so, then yes, according to A's clock at x=20, the event of the tachyon signal being received happens 6 seconds prior to the event of passing next to the x'=12 mark on B's ruler. Why do you bring this up? How is it relevant to the discussion?
Huh? The tachyon doesn't go back in time 6 seconds in A's frame. In A's frame, the event of the clock at x=20 passing next to the x'=12 mark on B's ruler is not simultaneous with the event of the tachyon signal being sent, these events are only simultaneous in B's frame. So, the fact that in A's frame the event of receiving the signal happens 6 seconds before the event of x=20 passing next to x'=12 in no way implies that the tachyon has gone backwards in time in this frame. In A's frame the order of the events is this:
t=0: tachyon signal emitted next to x=0 mark on A's ruler (and next to x'=0 mark on B's ruler)
t=10: tachyon signal received next to x=20 mark on A's ruler (and next to x'=20 mark on B's ruler)
t=16: x=20 mark on A's ruler passes next to x'=12 mark on B's ruler
On the other hand, in B's frame the order of these events is this:
t'=-10: tachyon signal received next to x'=20 mark on B's ruler (and next to x=20 mark on A's ruler)
t'=0: tachyon signal emitted next to x'=0 mark on B's ruler (and next to x=0 mark on A's ruler), AND simultaneously at a different location, x'=12 mark on B's ruler is passing next to x=20 mark on A's ruler.
I assume that by now you understand about the relativity of simultaneity, so you should be able to see that the fact that those two events happen simultaneously at t'=0 in B's frame does not imply they should be simultaneous in A's frame.
There is absolutely no need to use the addition of velocities equation in the proof, you can just focus on the coordinates assigned to the events of the signal being sent and the signal being received. However, it's also not hard to show that if you take two events on the worldline of an object moving at constant speed, and calculate dx and dt between these events in one frame and define the velocity in that frame as dx/dt, then if you apply the Lorentz transformation to these two events and calculate dx'/dt' in the new frame, you will find that the velocities in the two frames are related by the velocity addition equation, even in the case that dx>dt (i.e. you are looking at the worldline of a tachyon). If you'd like to see a proof of this, just ask.
I don't understand what "bi-directional assignment" means, and I don't know what "questions of logic, physics and conformity to the first postulate" you're referring to. Let me restate the steps in the proof as clearly as I can, and since you've already said you agree with the first 4 steps, maybe you can point out specifically what step you have a problem with:
1. Given the premise SR, we must assume that any events can be assigned space and time coordinates x and t in any inertial frame.
2. Given the premise FTL, there must be some inertial frame where, if you have the coordinates (x1,t1) of the signal being sent and the coordinates (x2,t2) of the signal being received, then in units where c=1, dx=|(x2-x1)| > dt=|(t2-t1)|
3. Given the premise SR, the coordinates assigned to the same event by different inertial frames must be related by the Lorentz transform.
4. Given 2 and 3, if you have a signal such that dx>dt for the transmission-event and the reception-event in one inertial frame, it is always possible to find a new inertial frame such the reception-event happens at an earlier time than the transmission-event in the new frame.
5. By the first postulate of SR, if it is possible in one frame to send a tachyon signal in such way that the reception-event happens at an earlier time than the transmission-event in that frame, it must be possible in any frame to send a tachyon signal in such a way that the reception-event happens earlier than the transmission-event in that frame.
6. If it's possible in any frame to send a tachyon signal in such a way that the reception-event happens earlier than the transmission-event in that frame, then it must be possible for one observer to send a tachyon message to the other and the second to then send a tachyon reply in such a way that the event of the first observer receiving the reply lies in the past light cone of the event of the first observer sending the original message, which is a clear violation of causality in every frame.
Can you point to a specific step that you disagree with here, where you think that it doesn't follow from the previous steps and the original premises of SR and FTL?
=JesseM;2050830]
No that is not necessary I have confirmed that for myself.
Perhaps I should say omnidirectional if a frame is considered at rest.
Without SR the concept of light being measured at the same speed traveling in the same direction as the inertial frame as it is measured traveling counter to the motion of the frame is a logical impossibility yes? SR provided a rational consistent explanation for how this was possible through the desynchronization of clocks. Correct??
Or do you have a different understanding?
Without this desynchronization the difference in the "bi-directional" measurements would reveal the motion of the system. Correct??
5) Above : It is not that I disagree with this at all. But you have just finished telling me how the reception event in frame A didnt occur earlier than the transmission event in that frame so how does this conform to the 1st postulate as you have outlined in 5)
How do you se this one:
The 1st P allows us to track a photon trans-reception happening in another frame , to observe this reception event and have complete agreement between frames. Correct??
In this case assume a photon flash was emitted simultaneous with the tachyons in A.
We can be sure that an observer in B at x'=6 could look over and observe the photon reception in A at x=10 , t=10 Correct??
Now instead of dx/2c=(dt=5) to derive tachyon time,, we instead do the equally valid ((dt=10)2c)=(dx=20) and derive the distance at that same time.
Make the normal assumption that traveling twice as fast as a photon it would cover twice the distance in the same time. From this we know that an observer in B at x'=12 should be able to look over and see the event of the tachyon reception at x=20 at t=25.99 True?
I am not saying I think this is any more valid than the former. Obviously it also makes no sense that a tachyon at 2c would take longer than a photon to reach that distance.
But as I understand the 1st P all valid physics principles should apply and produce agreement between frames. SO this seems to be a problem here where there are no problems whatever when dealing with v<or=c
As you yourself have pointed out [with the exception of light] any particle having a measured speed x in one frame cannot have the same measured speed in another frame.
Yet here we have an equal speed of 2c in both frames ,correct? Another instance where the specific values do not comply with the normal principles .
Would you agree that according to the principles of ballistic mechanics as applied to different inertial frames the closing velocity of a projectile wrt an observer frame Cw=(u+v)
must necessarily be greater than the parrallel relative velocity Pw=(u-v ) ?
That this relationship should carry through and hold with any transformation??
Would you agree?
As far as I can see it does hold true with the addition of velocities formula with all v< c
but it does not hold true for v=2c where (u+v)/ 1+uv < (u-v)/1-uv
It seems to me that this is a definite violation of the 1st P and that the conclusion from this would be that the addition formula also does not apply , just like the math for an inertial frame does not apply with v>c This seems to be clearly not physics as usual. Not to mention not logical. Or would you disagree?
I am pressed for time but I am thinking about your points. Thanks
=DaleSpam;2050736]No, clocks could not be synchronized by tachyons any more than they could be synchronized by baseballs or proton beams today. The Einstein synchronization procedure relies on the fact that light has the same speed in all reference frames. Baseballs, protons, and tachyons do not have the same speed in different reference frames.
How do you think that light could possibly have the same speed in all directions in all frames if it weren't for clocks being desynchronized the exact right amount to make this possible?
Would you not agree that in any frame with any motion the light method actually assures desynchronization not synchronization?
=Fredrik;2049132]No. Look at my previous reply to you (included below for completeness). If u, v and w are defined as in that post, the derivation of the velocity addition formula goes like this:
I thought this:
1) the gamma factor did not show up directly in the additions formula
2) the denominator in both equations looked very similar except for the sqrt operator.
I jumped to the conclusion that both u and v had been entered but that the sqrt operator had been eliminated in the course of the derivation.
I was wrong ,,not only in this conclusion but also in not taking the time to work it through before putting it out and wasting your time. For that I apologize.
My matrix math is a hazy memory so I can't follow the derivation well enough to understand how it manages to eliminate the gamma factor but that is a math mystery for another time
Arent the definitions essentially the same?? A state of uniform [non accelerated ] motion, the difference being the added SR condition of flat space-time and the Lorentz math?
The basic idea is the same in SR and pre-relativistic physics, but the details are different. Consider the properties of functions that represent a change of coordinates from one inertial frame F to another inertial frame F':
1. They are smooth functions (i.e. they can be differentiated as many times as you want).
2. They take straight lines to straight lines.
3. They take each 3-plane that's orthogonal to the 0 axis of F to a plane that's orthogonal to to the 0 axis of F'.
All of these hold in both theories, but the word "orthogonal" doesn't mean the same thing in both cases. In SR, we're talking about orthogonality with respect to the Minkowski metric instead of with respect to the Euclidean metric.
The definition of the product of two matrices is just
[tex](AB)_{ij}=\sum_k A_{ik}B_{kj}[/tex]
where e.g. [itex]A_{ik}[/itex] is the entry on row i, column k of the matrix A. So in the special case where A is a 2x2 matrix and B a 2x1 matrix, we get
[tex]\begin{pmatrix}a & b\\ c & d\end{pmatrix}\begin{pmatrix}x\\ y\end{pmatrix}=\begin{pmatrix}ax+by\\ cx+dy\end{pmatrix}[/tex]
The two-way speed of light is isotropic, constant, and frame invariant regardless of your synchronization procedure. The Einstein synchronization procedure just makes the one-way speed match the two-way speed.
Yes, although the clocks are only "desynchronized" in the frame where they are moving of course.
Yes, if all frames agreed on what it meant for clocks to be synchronized (i.e. if they all agreed about simultaneity), then it would be impossible for light to have the same speed in both directions in all frames. I still don't really understand what your original comment "The overall results of the application of the basic assumption to bi-directional assigments and the many questions that arise from those results." Application of what basic assumption? And what does "the basic assumption to bi-directional assignments" mean? I understand that in the context of light you are using "bi-directional" to mean measuring the speed of light in both directions is, but I don't understand what "bi-directional assignments" are. What is being assigned, and what is it being assigned to?
5) just said it would be possible to send a different tachyon signal that goes back in time in A's coordinates, it doesn't say that that specific tachyon signal (the one that was sent at (0,0) and received at (20,10) in A) is going back in time in A's coordinates. As an analogy, if I see a missile moving at 0.5c in my frame, and in your frame I am moving at 0.5c in the same direction so in your frame the missile is moving at (0.5c + 0.5c)/(1 + 0.5*0.5) = 0.8c, then by the first postulate it must be possible for me to see a missile moving at 0.8c in my frame...but this doesn't mean that particular missile should be measured to be moving at 0.8c in my frame, since I already measured it to be moving at 0.5c in my frame. The first postulate just implies I could send out a different missile which would be moving at 0.8c in my frame, and similarly the first postulate implies A could see a different tachyon signal which was received before it was transmitted in A's frame.
I understand what you're saying, but your language is confused here, the events of a photon being sent and received don't happen "in" any particular frame, they're just events, different frames assign them different coordinates. The second postulate (is that what you meant to write?) does say that if one frame finds that dx=dt for two events (in units where c=1, so both events would lie on the worldline of a photon), then another frame will also find that dx'=dt' when it looks at the same events in its own coordinates.
What do you mean by "look over"? If you're talking about a local observation, the reception event wouldn't happen next to x'=6 in B's frame, it'd happen next to x' = 1.666..*(10 - 0.8*10)=3.333... in B's frame (and so naturally it'd also happen at t'=3.333... in B's frame).
Distance at the same time in whose frame? Since you're using A's dt of 10 I assume you mean A's frame here...it's true that in A's frame, the event of the photon being received at x=10, t=10 is simultaneous with the event of the tachyon being received at x=20, t=10. But of course, these two reception-events are not simultaneous in B's frame, where the photon reception-event happens at t'=3.333... while the tachyon reception-event happens at t'=-10. If you want to assume the tachyon signal was just measured to be passing by the origins of the two frames rather than actually being emitted at that point, then we could say that in B's frame at t'=3.333... the tachyon would have been at position x'=-6.666... (and in A's frame, this event on the tachyon's worldline would be at x=-6.666..., and t=-3.333...)
No, that doesn't make any sense. First of all, the tachyon is only "traveling twice as fast as a photon" in A's frame, that doesn't necessarily mean it is traveling twice as fast in other frames since a tachyon's speed would not be frame-invariant (in fact in B's frame it happens to be true that it is, although in B's frame the tachyon seems to be traveling in the opposite direction, so its velocity is different even if its speed is not). Second, where exactly did you get t=25.99? I don't get your argument at all.
Since your argument doesn't make any sense to me I'd guess you've just made a mistake somewhere, but I can't tell where your mistake is unless you actually explain the argument in detail instead of just throwing out random numbers.
No, I said it can't have the same speed in all frames. It is certainly possible for a single sublight object to be traveling at speed S in the +x direction in one frame and speed S in the -x direction in another frame (opposite velocities but same speed). In my example above with the missile moving at 0.5c in my frame but 0.8c in yours, in your frame I am moving at 0.5c in the +x direction, while in the missile's frame I am moving at 0.5c in the -x direction. This is the same sort of thing that's going on with the tachyon, since it's going at 2c in the +x direction in frame A and 2c in the -x' direction in B's frame (since in B's frame the tachyon is further in the -x' direction at later times--at t'=-10 it's at x'=20 but at t'=0 it's at x'=0).
No. In the missile example above, in your frame the missile is moving at 0.8c while I am moving at 0.5c, so in your frame the closing velocity is 0.3c. But in my frame the velocity of the missile relative to me is 0.5c.
You're neglecting to consider the fact that velocity can be negative in the case of an object moving in the -x direction instead of the +x direction.
Even if what you were saying was true, how would it be a violation of the first postulate? The first postulate doesn't say that the laws that tachyons follow should be identical to the laws that sublight particles follow, it just says that whatever laws tachyons are observed to follow in one inertial frame, they must follow the same laws in every other inertial frame.
