Heat addition process in dual cycle
In a dual cycle, heat addition occurs first at constant volume and then at constant pressure to maximize energy retrieval. This sequence allows for more efficient energy conversion during the cycle. The PV diagram illustrates the areas enclosed by the curves, highlighting the net work produced by the cycle. The area under the curve represents the work done, emphasizing the importance of the heat addition process order. Understanding this process is crucial for optimizing performance in dual cycle engines.
suraj 27
why in dual cycle heat addition at constant volume process is first then after heat addition at constant pressure process is done?
Thank you jack
My idea is that I want to use immerse Whitetail Antlers in a fishtank to measure their volumetric displacement (the Boone and Crockett system is the current record measurement standard to place in a juxtaposition with) I would use some sight glass plumbed into the side of the tank to get the change in height so that I can multiply by the tank cross-section. Simple Idea. But... Is there a simple mechanical way to amplify the height in the sight glass to increase measurement precision...
  • · Replies 19 ·
  • · Replies 33 ·
