Heat Conduction Initial Problem Set Up
1 reply · 5K views
timman_24
I need to set up the mathematical formulation of the following heat conduction scenarios:
a) A slab in [itex]0\le x \le L[/itex] is initially at a temperature f(x). For times t>0 the boundary at x=o is kept insulated and the boundary at x=L dissipates heat by convection into the medium at zero temperature.
b)A semi-infinite region [itex]0\le x \le \infty[/itex] is initially at temperature f(x). For times t>0, heat is generated in the medium at a constant rate of g (constant), while the boundary at x=0 is kept at zero temperature.
c) A solid cylinder [itex]0\le r \le b[/itex] is initially at a temperature f(r). For times t>0 heat is generated in the medium at a rate of g(r), while the boundary at r=b dissipates heat by convection into a medium at zero temperature.
d) A solid sphere [itex]0\le r \le b[/itex] is initially at temperature f(r). For times t>0, heat is generated in the medium at a rate of g(r), while the boundary at r=b is kept at a uniform temperature T'.
2. The attempt at a solution
Problem a)
Solution:
[itex]\frac{1}{\alpha}\frac{\partial T}{\partial t}=\frac{\partial ^2 T}{\partial x^2 }[/itex]
IC: T(x,0)=f(x)
BC:
1.) Insulated Boundary:[itex]q\prime(0,t)=0[/itex]
2.) Convection Boundary:[itex]k\frac{\partial T}{\partial x}|_L =-hT(L,t)[/itex]
Problem b)
Solution: [itex]\frac{1}{\alpha}\frac{\partial T}{\partial t}=\frac{\partial ^2 T}{\partial x^2 }+\frac{1}{k}g[/itex]
IC: T(x,0)=f(x)
BC:
1.) T(0,t)=0
2.) Is there another boundary for the [itex]x=\infty[/itex]?
Problem c)
Solution: [itex]\frac{1}{\alpha}\frac{\partial T}{\partial t}=\frac{\partial ^2 T}{\partial r^2 }+\frac{1}{k}g(r)[/itex]
IC: T(r,0)=f(r)
BC:
[itex]k\frac{\partial T}{\partial r}=-hT[/itex]
Problem d)
IC: T(r,o)=f(r)
BC: T(b,t)=T'
3. Discussion
I do not know if I need another boundary condition on question b for the infinite side, I don't know what to do there. Also, c and d should be rather easy to express due to symmetry, but it almost seems too easy. Is there anything I am missing in my mathematical representations of the physical systems described? Any guidance would be very appreciated.
