Heating Saline with an Element: Is it Possible?
  • Thread starter Thread starter joeha
    Element Heating
The discussion revolves around the possibility of heating a saline solution by adding a specific element that would cause an exothermic reaction. Participants explore various substances and their potential to raise the temperature of the saline without an external heating source.
  • One participant inquires whether any element can be added to saline to heat it up, seeking clarification on the constraints of the task.
  • Another participant suggests adding hot water as a simple solution.
  • Several participants propose various substances, including hot ethanol, concentrated sulfuric acid, and sodium, but note the need for clearer constraints on the desired outcome.
  • A participant clarifies that they are looking for an element that can react exothermically with a saline solution without an external heat source.
  • There is a discussion about the implications of using an element that would contaminate the solution after the reaction.
Participants do not reach a consensus on a specific element that would achieve the desired heating effect. There are competing views on the feasibility of the task and the implications of contamination from the reaction products.
Participants express uncertainty regarding the specific conditions and constraints of the heating process, including the nature of the saline solution and the potential contamination from reaction products.
joeha
Hi there. Is there any element, when exposed to saline, will cause the saline to heat up? More to the point, I would like to add something to a jar of saline and heat it up. Is that possible?
Thanks, ~J
Chemistry news on Phys.org
Add hot water?
Hi Borek. Yea, besides that. Thanks though.
~ J
Hot ethanol? Concentrated sulfuric acid? Piece of sodium?
In case you are missing the point - you have not explained what are the constraints and what you are really trying to do, so you can't expect much better answers.
For sure. Let me explain.
With an exterior heating source like flame or warmer solution, I'm looking to start with cold saline solution (50º as an example) and add element X in order to heat the solution (say 60º).
All I really need to know is whether or not there is any element that is capable of a reaction like this? Is it possible? That's the jist of it.
Thanks, ~ Joe D
If you have an external source of heat doesn't matter what element you add, you will end with a heated saline.
Sorry man. I'm new to this. It should read "Without an external heating source..."
That changes things a bit.
So basically you are looking for an element that will react exothermically with a diluted water solution, containing some salt and small amounts of organic compounds?
Exactly.
And you are aware of the fact after the reaction the original solution will be highly contaminated with the reaction products?
I didn't think about that and it's ok if it is.
  • · Replies 131 ·
12K
