This discussion centers on the feasibility of heating water to 60°C using a 9V battery. It is established that a single 9V battery can heat only 0.08 kg of water to the desired temperature, which is insufficient for practical use, such as a shower. The calculations indicate that to match a typical shower flow rate of 5 liters per minute, approximately thirty 9V batteries would be required, and they would deplete quickly. Alternatives like tankless water heaters and secondary loop systems are recommended for efficient hot water delivery.
- Understanding of specific heat capacity, particularly for water (4181 J/kg°C).
- Basic knowledge of electrical concepts, including watt-hours and amp-hours.
- Familiarity with battery specifications, particularly 9V and lithium-ion batteries.
- Awareness of plumbing systems and hot water delivery methods.
- Research the efficiency and specifications of tankless hot water heaters.
- Learn about the design and benefits of secondary loop systems for hot water delivery.
- Investigate the specific heat calculations for different volumes of water and temperature changes.
- Explore the performance characteristics of lithium-ion batteries compared to traditional batteries for heating applications.
Homeowners, plumbers, electrical engineers, and anyone interested in optimizing hot water delivery systems and energy efficiency in residential settings.
