Help about length contraction and spacewarps
The discussion focuses on the concepts of length contraction and time dilation in special relativity, specifically using the starship ENTERPRISE and a spacecraft traveling at 60% of the speed of light. The length of the ENTERPRISE, which is 1200m at rest, appears contracted when observed at 0.75c. The gamma factor (γ) is crucial for calculating the perceived length and time experienced by observers on the spacecraft compared to Earth. The correct application of the gamma factor is essential to avoid confusion between length and time in relativistic scenarios.
  • Understanding of special relativity concepts
  • Familiarity with the gamma factor (γ) in relativistic physics
  • Basic knowledge of length contraction equations
  • Ability to perform calculations involving speeds as a fraction of the speed of light (c)
  • Study the derivation and applications of the gamma factor (γ) in special relativity
  • Learn about the mathematical formulation of length contraction and time dilation
  • Explore practical examples of relativistic effects in high-speed travel scenarios
  • Investigate the implications of special relativity on GPS technology and satellite communications
Students of physics, educators teaching special relativity, and anyone interested in understanding the effects of high-speed travel on space and time.
philadelphia
I have two problems that I got confused with and I am not sure if I am doing right
1) The starship ENTERPRISE 1200m long when at rest. How long would it seem to be to someone watching the ship pass by them at 0.75c?
length contraction
\Delta t{}0 = Find \gamma \Deltat' ?
1200/0.75c
2) A spacecraft 500m long is traveling at 60% of the speed of light (3 x 10^8 m/s)
a) Find \gamma
b) If 10 years go by one earth, how many years go by according to people on board the spacecraft ?
c)how long is the spacecraft according to Earth observers
length contraction
I only tried finding a:
gamma = L(sub 0)/ L'
60% of speed of light is 180000000 = L (sub 0)
180000000 / 500 = 36000000 years?
is this correct?
Those aren't the right equations. Gamma has a specific definition and it's not speed.
You also seem to mix up length and time; this may work for these problems, but it will cause you grief in the future.
In special relativity, the gamma factor basically gives you the ratio of one frame of reference to the other (space and time): it's particularly convenient when you express the speeds in terms of c.
So: when an object is moving at 0.75c relative to another, this ratio reduces to 4/sqrt(7), as you should verify..
- In your first problem, the length of the "moving" object will appear contracted relative to a "fixed" frame of reference (earth)
- In the second one, time is "dilatated" in the spaceship
Just use the gamma factor in both cases to convert from one frame of reference to the other.
  • · Replies 29 ·
