Help- comparing objects in free fall
  • Thread starter Thread starter guvava
    Fall Free fall
The problem involves two objects in free fall: an egg thrown downwards from a bridge and a rock thrown upwards from a fisherman standing below. The task is to determine the speed of the rock when both objects are at the same height above the water, utilizing concepts from kinematics, free fall, and projectile motion.
  • Participants discuss setting up equations for both the egg and the rock to find their heights over time, considering initial velocities and gravitational acceleration. There is confusion regarding the correct interpretation of displacement and height, particularly how to account for the height of the bridge.
Some participants have attempted to derive equations for height and time but have encountered difficulties, particularly with the inclusion of the bridge height in their calculations. There is ongoing exploration of how to properly set the equations equal to each other and resolve the resulting expressions. Guidance has been offered regarding the need to adjust for the height of the bridge, but no consensus on a definitive approach has been reached.
Participants note the challenge of correctly applying kinematic equations due to the initial conditions and the height difference, leading to confusion about the relationship between displacement and height in this context.
guvava
Problem: An egg is thrown downwards at 2 m/s from the top of a bridge. At the same moment, a fisherman standing in a stream 30 m beneath the bridge throws a rock upwards at 15 m/s.
How fast will the stone be moving when it and the egg are at the same height above the water?
This is homework from chapters involving the kinematic equations, free fall, and projectile motion
I know I first need to find the distance above the stream at which the rock and egg are at the same place at the same time but I don't know how to do this with the information given and the kinematic equations. I've tried solving using the down direction as positive and up as negative. I can't use displacement=Vi*t+1/2g*t squared for each and set them equal to each other because displacement may not be equal when the two objects meet (this comes out unsolveable when I've tried).
I'm terribly stuck after several hours on this problem. How do I solve it? Thanks!
Suppose they meet at a height h from the ground. You can write an eqn for the stone connecting h, its initial velo, and t, which will be h = vs_i - 1/2 gt^2. Similarly for the egg. Now eliminate h and find t. Then use the eqn you've written.
It looks like that is what I've already tried to do using h=Vit+1/2gt^2. I keep ending up with 2t=-15t, which doesn't work.
Your equation doesn't include t; isn't that incorrect?
You're right. Displacement won't be equal. The height of the egg from the ground is not it's displacement, but rather, 30 minus the distance it has traveled is it's height. You need to take the 30m into account. Then just set those equations equal to each other once you have taken the 30m into account, and you should be able to solve for the time. From there, just plug it into the ([tex]v_f = v_i + a t[/tex]) equation to solve for the stone's velocity.
By the way, what is the actual answer? When I solved it, I got 3.162 m/s, but I think I screwed up the value of g (If it is negative or positive) when I put it in the equations.
(I've was working on this problem for about 40 minutes, and I couldn't get the answer. I kept getting odd answers like you did, such as negative times. Then I went to go get something to eat and I realized I forgot the 30m when I came back.)
I found time was 1.7 and got 2.25 for the velocity. Thanks! I didn't think about the difference between h and 30.
Which eqn did you mean?
