Help Prove Lim x-infinity cos(nx) = dne
  • Thread starter Thread starter bluemax43
The limit of cos(nx) as x approaches negative infinity does not exist. This conclusion is based on the behavior of the cosine function, which oscillates between -1 and 1 for non-multiples of 2π, while converging to 1 for multiples of 2π. The discussion emphasizes the use of epsilon-delta proofs to demonstrate the non-existence of the limit by comparing sequences that diverge. Participants confirmed the reasoning that selecting specific sequences can effectively illustrate the limit's non-existence.
  • Understanding of limits in calculus
  • Familiarity with the cosine function and its properties
  • Knowledge of epsilon-delta proofs
  • Basic concepts of sequences in mathematical analysis
  • Study the properties of the cosine function in detail
  • Learn about epsilon-delta proofs and their applications in limits
  • Explore the concept of oscillating functions and their limits
  • Investigate examples of limits that do not exist using sequences
Students studying calculus, particularly those focusing on limits and sequences, as well as educators seeking to clarify the concept of non-existent limits in mathematical analysis.
bluemax43
Help! Prove Lim x--infinity cos(nx) = dne
Hey guys! I am new here however, I have been lurking around for a while. I need some help with a problem that I am currently working on. Here it is:
Prove Lim x--infinity cos(nx) = does not exist
As of now, I am not quite sure how to approach the problem. I know that I can say that if x is a multiple of 2π then it will converge to 1 however, if it is not a multiple of 2π then it will simply oscillate until infinity. As such, the limit does not exist. However, I doubt that that is what is required of the problem. I am thinking that there must be some systematic setup that I can use to prove this problem otherwise. Is there such a way or is my reasoning correct?
In our other problems, we used epsilon-delta proofs to prove that certain functions converged to p.
Anythings would help! Thanks guys!
This reminds of a problem I had to do recently. Here are my thoughts:
Pick 2 sequences (x_{n})_{n} and (y_{n})_{n} such that lim x_{n} = infinity as n tends to infinity and lim y_{n} = infinity as n tends to infinity. Then show that lim f(x_{n}) ≠ lim f(y_{n}), therefore the limit does not exist.
So if I understand your statement correctly, I should choose for example cos(2πn) and show that that the limit goes to 1 and then pick any other to show that it goes to some other number? So basically my reasoning was right?
Yes it is correct.
got it thanks!
  • · Replies 23 ·
9K
