Help searching for SAMs (self-assembling monolayers) for a project
The discussion centers on the search for a self-assembling monolayer (SAM) that can effectively bind to triethylamine (TEA) and deposit onto graphene or transition metal dichalcogenides (TMDs) via evaporation, while also being low in toxicity. The challenge lies in achieving effective doping on both sides of the material, as p-dopants would only affect one side, complicating the interaction with TEA. Covalent SAMs, such as benzene diazonium salts, offer good coverage but may degrade conductivity, while noncovalent SAMs, like functionalized pyrenes, are more suitable for TMDs. The feasibility of binding TEA is questioned, with suggestions leaning towards non-covalent interactions, particularly through acid-base interactions with carboxyl groups. The discussion also touches on the concept of electrostatic doping and references previous work on Janus membranes, indicating that clarity on the intended application is necessary for more targeted advice.
SpinzTronics
TL;DR
Need help finding a Self-assembling monolayer that binds to Triethylamine that can be deposited onto a substrate like graphene via evaporation.
Does anyone know of a self-assembling monolayer that can bind to triethylamine,deposit onto graphene/TMD by evaporation, and that has "low toxicity" (that I could use in the lab)? P-dopants could only help dope one side of the material and TEA would react on the other but that is very hard to achieve. If it could be an n-dopant I think that would work to have the surface group bind readily with TEA. I have analyzed the entire list here Chem. Soc. Rev., 2018, 47, 6 but it is not good so far. Thx!
Chemistry news on Phys.org
It’s unclear what you’re trying to do and whether or not what you’re proposing is the best way to do it.
Are you looking for a SAM that is covalently bound or not? SAMs that are covalently bound are easier to get good coverage with, but they degrade the conductivity of the material. Good covalent SAMs include just about any benzene diazonium salt. Good noncovalent SAMs are probably limited to functionalized pyrenes or other PAHs. There is a smattering of other self-assembling adsorbates (including graphene-binding peptides) that might be of interest to you. Typically deposition of all of the above is done in solution phase, not vapor phase. TMDs are more amenable to noncovalent SAMs, but I’m less familiar with the state of the art there.
Also, what do you mean by bind TEA? Covalently will be difficult; maybe a dative bond with an organoboron, or else forming a bond to make a charged ammonium. The other option is non-covalently through an acid-base interaction. This is probably your best bet: to use a fairly acidic carboxyl group to protonate the TEA and rely on the electrostatic interaction of the ammonium with the carboxylate.
BUT: it also sounds like you want to electrostatically dope graphene with TEA, which is usually a physisorptive interaction, so no acid-base. Moreover, you say you want to p-dope one side and (presumably) use TEA to n-dope the other side. Folks have done somewhat similar stuff in the past; look up “Janus membrane” for an idea of what’s been done. Like I said, it’s unclear what you’re after, so it’s hard to give good advice.
I came.across a headline and read some of the article, so I was curious. Scientists discover that gold is a 'reactive metal' by accidentally creating a new material in the lab https://www.earth.com/news/discovery-that-gold-is-reactive-metal-by-creating-gold-hydride-in-lab-experiment/ From SLAC - A SLAC team unexpectedly formed gold hydride in an experiment that could pave the way for studying materials under extreme conditions like those found inside certain planets and stars undergoing...
