MHB Help solving a linear equation in one variable
The discussion focuses on solving the linear equation 15 + 1/2 = 0.60(20x). Participants clarify the equation and suggest combining terms on the left side and distributing on the right. The correct approach leads to the simplified equation 15 + 1/2 = 12x, which can be further simplified to 31/2 = 12x. Ultimately, the solution for x is determined to be 31/24 after performing the necessary algebraic steps. The conversation emphasizes the importance of correctly handling fractions and finding common denominators.
kmooney
15+1/2=0.60(20x)
Mathematics news on Phys.org
Re: pre-algebra help
Hello and welcome to MHB! (Wave)
Do you have any thoughts on how you should begin?
you need to put the 1/2x on both sides
Hi kmooney,
Just to confirm, is this the equation?
$$15+\frac{1}{2}=0.60(20x)$$
Or is it $$15+\frac{1}{2x}=0.60(20x)$$
the first one
Do you mean $$\frac{1}{2}x$$ or $$\frac{1}{2x}$$?
And where in the original equation do you see anything like that? If it were me, I would combine terms on the left side and distribute the 0.60 on the right. What do you get after doing this?
1/2
I would simply add the 1/2 to the 15, and multiply the 0.60 with the 20...what does the equation look like now?
edit: I have retitled this topic to indicate the type of problem for which help is being asked. A topic title ideally will indicate the nature of the problem being discussed. :D
ok so I take 15+1/2=.60*20=15 1/2x=12x does this look right
The right side of the equation is correct as $0.60\cdot20x=12x$, but how did you get an $x$ on the left side?
o sorry hit it by mistake
Okay, no worries, so we now have:
$$15+\frac{1}{2}=12x$$
What do we get when we perform the addition on the left side?
put the 12 over the same denominator
15/1+1/2=16/3
No, we are only want to add the $15$ to the $$\frac{1}{2}$$, so how can we write $15$ so that it is some number over $2$? In other words, how can we get a common denominator on the left side?
kmooney said:
15/1+1/2=16/3
No, while we can mutiply across when multiplying fractions, we cannot add across when adding them. We need to get a common denominator, then put the sum of the numerators over this common denominator. For example:
$$3+\frac{1}{3}=\frac{9}{3}+\frac{1}{3}=\frac{9+1}{3}=\frac{10}{3}$$
15+ 1/2 =0.60(20x)
multiply 0.60(20x)=12.00x
The answer be 12x
15+ 1/2=12x
15=12x-1/2 hence a+b=c then a=c-b
find LCM of 2 and 1
then [24x-1]/2
15=[24x-1]/2
15*2=24x-1 hence a/b=c then a=bc
30=24x-1
31=24x
x=31/24
tutor said:
15+ 1/2 =0.60(20x)
The answer be 12x
15+ 1/2=12x
find LCM of 2 and 1
then [24x-1]/2
15=[24x-1]/2
30=24x-1
31=24x
x=31/24
Why would you first subtract through by $\dfrac{1}{2}$? It is okay, but seems overly complicated, to then have to add it back after multiplying through by 2.
I would proceed as follows:
Combine terms on the left:
$$\frac{31}{2}=12x$$
Multiply through by 2:
$$31=24x$$
Divide through by 24, and arrange as:
$$x=\frac{31}{24}$$
I realize that this problem has thoroughly been answered, but this stuff is fun for me! :D
I would begin by first multiplying the $$20x$$ by the $$0.60$$.
As such we would have,
Then we would need to condense the left side of the equation.
Then I would divide the 12 over.
$$\frac{1}{12}\times(\frac{31}{2})=(12x)\times \frac{1}{12}$$
Then we would get the final answer that everyone else has arrived at!
$$x=\frac{31}{24}$$
Solve for x and then your need to distribute the numbers to get the value of the variable.
