Solving 2√x y' + y + 4√x = 0 with y(1) = 2
12 replies · 3K views
middieman147
Given:
Solve the initial value problem 2(√x)y'+y+4(√x) ; y(1)=2
I am having trouble separating the x's and y's in order to integrate. I keep coming up with:
dy/dx +y/(2(√x))=2...
What do I keep missing here? I am pretty sure you leave the y(1)=2 alone until you are finished with the integration, in which case you plug in x=1 and y=2 to solve for the constant. Is this the correct thought process for this problem?
Thanks.
Or can I substitute in the y(1) for the 2 on the right side of the equation and make all the other x's equal to 1?
let
and
find the integrating factor
and then use
hope that help :)
Ok so now I have:
y'-y/(2√(x))=2
p(x)=-1/(2√x) q(x)=2
u(x)=e∫(-1/(2√x))=e-√x
y=e√x(2e-√x)+C
y=2+C
this is the solution for all values of x with C=0, correct? Or am I forgetting a step?
Thanks
you firstly have to integrate the right side
before you multiply it by
Ok:
y=-4sqrt(x)-4+C with C=10 is the answer given the IC y(1)=2?
when u divide the right side after integrating by
, u should also divide the constant too so it should be
middieman147 said:
Given:
Do you mean [itex]2\sqrt{x}y'+ y= 4\sqrt{x}[/itex]?
Thanks.
yes I do.
thanks.
wouldn't that just be another constant?
so instead of writing Ce^sqrt(x), you could just consider it a new constant
C is a constant, but [itex]Ce^\sqrt{x}[/itex] is definitely not a constant.
isnt that irrelevant since there is an IC? wouldn't the x in that expression =1 and then just equal C multiplied by another constant?edit: Are you saying i should divide 10 by e^1 to find the constant?
No, that's not irrelevant.
In using the Initial Condition to evaluate the constant, C , you do set x=1, but in the overall solution there is a term [itex]Ce^\sqrt{x}[/itex], unless the Initial Condition gives C=0, which is not the case here.
