Help understanding an experiment set up
  • Thread starter Thread starter dRic2
    Experiment Set
The discussion revolves around understanding the composition of an inlet mixture in a combustion-related paper, which actually pertains to pyrolysis. The user is confused about the absence of O2 in the mixture and seeks clarification on calculating mole fractions of isobutene, O2, and N2. It is clarified that since the paper focuses on pyrolysis, O2 is not required, leading to the conclusion that the inlet mixture consists of equal parts isobutene and nitrogen. The user realizes their misunderstanding regarding the experiment's context. This highlights the importance of accurately interpreting experimental setups in scientific literature.
dRic2
Hi, I'm reading a paper about combustion and I can't understand the composition of the inlet mixture. Here's what the paper says:
"A known flow rate of the isobutene (Matheson, TriGas, 99.5%) in nitrogen (General Air, 99.998%) was introduced into a 6mm ID quartz reactor that was heated in an electric furnace..."
I need to calculate the mole fraction of isbutene, O2, and N2 but I don't understand the above sentence. Any suggestion would be of great help!
PS. isobutene = isobutylene
PSS: I find very strange that in a combustion experiment is not mentioned the amount of O2 in the mixture... Maybe I'm overlooking something, but I didn't find anything else in the paper
PSS: I forgot an important part: there is a line that says "N2/iC4H8 = 50/50 % mol"
Can you give the reference?
Check whether the paper is about "combustion" or "pyrolysis".
Likes berkeman and dRic2
Oh, I'm an idiot...
It says pyrolysis so no O2 is needed, then I assume the inlet mixture is just 0.5 isobutene and 0.5 N2, right ?
I need to anneal 5052 aluminum for a home project. Google has given me mixed results on how to do this. Short version is that I'm doing some heavy forming on a piece of 5052-H32 and I'm running into issues with it work hardening. I've tried the Sharpie trick with a propane torch. But I'm not sure this is doing anything. I'm also seeing conflicting opinions whether to quench or air cool. So I'm looking for some expert opinions. (Oven heating is not an option due to size.) Thanks. edit: The...
11K
  • · Replies 19 ·
