Help with a boolean problem
  • Thread starter Thread starter krispiekr3am
12 replies · 5K views · last reply
krispiekr3am
Can someone help me with this problem.
Mathematics news on Phys.org
i wanted to proof that that boolean is true. thank you
I need to simplify the following expressions in XOR The simplified answer is only one variable or its complement
I can't see the JPEG yet. Why don't you explain the problem and what you've done so far?
One alternative - you can generate a truth table of the expression and see from the table what it is done, but I doubt that any Math teacher would like that, anyway
For example a
I believe that you can rearrange the terms and you can simplify them
e.g.
A'B XOR BC XOR AB XOR B'C'
becomes
A'B XOR AB XOR BC XOR B'C'
note:
A'B XOR AB - what does that tell you?
you can simplyfiy this to get just one variable
then take BC XOR B'C'
how can you get a more simple equivalent of this of a form Y XOR Z where Y and Z represent one variable e.g. B or C'.
When you have this done you should see the answer.
Example b is a tautology.
Bc Xor B'c'
=(b Xor C)'
=b+c'
=b' Xor C = Bc + B'c'
= B=c?
So The Answer Would Be B Xor (b = C) = 0??
TO approve this other problem
AB XOR A'B XOR A'B' XOR B'A
B(A XOR A') XOR B'(A' XOR A)
we know that A XOR A' =1
B XOR B'
and from one of the XOR property, X XOR X' = 1
THEREFORE B EQUALY 1?
THE SOLUTION WOULD BE 1?
let me know if that right?
i think i did the 1st problem wrong...
here is the simplied solution
A'B xor BC xor AB xor B'C'
becomes
A'B xor AB xor BC xor B'C'
A'B xor AB = B (we know that A A' =1)
BC xor B'C'
= (B xor C')(C xor B')
B xor (B xor C')(C xor B')
this is just one possibility:
step 1. - rearrange (correct)
step 2 - A'B xor AB is equivalent to just using B (correct), we have now
B xor BC xor B'C'
step 3 - BC xor B'C' is equivalent to B xor C' we are allowed to do this, since substituiting this will not alter the value of the overall truth table
B xor B xor C'
step 4 - B xor B will always be 0 we have now
0 xor C'
step 5 - 0 xor C' depends only on the value of C'
result: C'
this is ofcorse just one possibility.
you got the B example right.
what has A A' got to do with it?
Thank You So Much. That Really Helped.
Thanks Everyone
