Help with homework equations
  • Thread starter rado5
    Homework
7 replies · 3K views · last reply
rado5
Handwritten solution on lined paper for a conical pendulum: torque derivation with tension T cos α = mg, F = -mg tan α e_r, then τ = mgl tan α sin α e_θ versus τ = mgl sin α e_θ, with a note asking what is wrong.
  • Handwritten solution to a conical pendulum torque problem, with the derivation of tension, force and torque in blue ink, ending in a note that tan(alpha) should be sin(alpha).
hi rado5! :smile:
(have an alpha: α and an omega: ω and a tau: τ :wink:)
to clarify: is this a mass m on a string of length l and tension T rotating at angle α with angular velocity ω?
or is there also a horizontal cable with tension F? :confused:
assuming the former, you've calculated τ (about the vertical axis) using the wrong force …
τ is r x -mgz, not r x F
(T and F don't count because they go through the vertical axis; F also doesn't count if there's no horizontal cable, because then you just invented F) :wink:
Hi tiny-tim!
Thank you very much for your kind help.
Yes, this is a mass m on a string of length l and tension T rotating at angle α with angular velocity ω.
Handwritten derivation on lined paper: torque tau = r x (-mg K) gives |tau| = l mg sin alpha, so tau = mgl sin alpha e_theta; then L = mlrw e_r, dL/dt = mlrw e_theta = lF e_theta, and dL/dt = mgl e_theta, with the question of where sin alpha belongs.
  • Handwritten derivation of torque and angular momentum for a pendulum: tau = r x (-mg K) gives |tau| = lmg sin(alpha), then tau = mgl sin(alpha) e_theta; dL/dt = mlrw e_theta = lF e_theta, with F = mg giving mgl e_theta, noting a sin(alpha) term is missing.
hi rado5! :smile:
i'm getting confused … it would be easier if you typed your answer, instead of giving us a photo of your handwriting
you're trying to do τ = r x Fnet = dL/dt
but about the vertical axis, L is constant, and τ is zero
we solve this sort of problem with the ordinary linear F = ma equation​
Hi tiny-tim!
There are two problems in my book. The first one is an example with its solution. As I told you before the solution is [tex]\vec{\tau}=mglsin\alpha \vec{e_{\theta}}[/tex] for the problem [tex]\vec{\tau}= \vec{r} \times \vec{F}[/tex]. The second one is a problem with no solution which asks "Is [tex]\vec{\tau}= \frac{d\vec{L}}{dt}[/tex] correct for [tex]\vec{\tau}= \vec{r} \times \vec{F}[/tex] in the first example". I have been trying to show that it must be correct. I mean I have to show that [tex]\vec{\tau}= \vec{r} \times \vec{F} = \frac{d\vec{L}}{dt}[/tex].
oh i see now!
the confusion is that you're not treating τ and L as vectors
your τ is calculated about the top of the string, and is r x -mgz,
with (as you say) magnitude mglsinα, and direction tangential
your L (calculated about the top of the string) is r x v, which is sticking up diagonally outward
L's vertical component is constant, so you need only bother with d/dt of its horizontal component …
that should give you the required τ = dL/dt :smile:
Hi tiny-tim!
I think my book solved the first example in a bad way!
I was very naive about [tex]\vec{L}[/tex], because I wrote [tex]\vec{L} = mlr \omega \vec{e_{r}}[/tex] which is wrong! Because [tex]\vec{r} = lsin \alpha \vec{e_{r}} - lcos \alpha \vec{k}[/tex] and [tex]\vec{v} = r \omega \vec{e_{\theta}}[/tex] so [tex]\vec{L} = \vec{r} \times mv = mlr \omega cos \alpha \vec{e_{r}} + mlr \omega sin \alpha \vec{k}[/tex].
Now we have [tex]\vec{\tau}= \frac{d \vec{L}}{dt} = mlr \omega ^{2} cos \alpha \vec{e_{\theta}} = lFcos \alpha \vec{e_{\theta}}[/tex].
[tex]\vec{\tau} = lmgtan \alpha cos \alpha \vec{e_{\theta}}[/tex]
[tex]\vec{\tau} = mglsin \alpha \vec{e_{\theta}}[/tex] which is the right answer!
