Help with inverse Laplace transforms
The discussion focuses on solving three inverse Laplace transforms. The first transform, (s-1)/(s^2 + 8s + 17), involves completing the square, but there is confusion regarding the coefficient of the sine term in the final answer, which should be -5 instead of -1. For the second transform, (s+3)/(s^2 + 4s), participants suggest factoring and completing the square to simplify the expression. The third transform, 2/[(s+1)*(s^2 + 1)], requires proper setup for partial fractions, with advice to use A/(s+1) and (Bs + C)/(s^2 + 1) for accurate decomposition. Overall, the thread emphasizes the importance of careful algebraic manipulation and the use of Laplace transform tables for solving these problems.
rusty009
I have three inverse laplace transforms I can't solve, they are,
i)
ii)
(s+3)/(s^2 + 4s)
iii)
2/[(s+1)*(s^2 + 1)]
The laplace transform table,
http://en.wikipedia.org/wiki/Laplace_transform#Table_of_selected_Laplace_transforms
i) I completed the square and got,
-->(s-1)/[(s+4)^2 -1]
then split up into, s/[(s+4)^2 -1] and -1/[(s+4)^2 -1]
my answer was e^-4t *cos(t) - e^-4t *sin(t)
but the answer is e^-4t *cos(t) - 5e^-4t *sin(t) , I do not know where the 5 has come from ?ii) I'm not sure where to start on this one
(s+3)/(s^2 + 4s) , I have taken out a factor of 1/s but I am not sure were to go from there.iii) For this one, I'm not having problem with the actual laplace but rather partial fractions, what I have done,
2/[(s+1)*(s^2 + 1)] = A/(s+1) + B/(s^2 + 1)
A(s^2 + 1) + B(s+1) = 2
for s=-1 I found A= 1
but I'm stuck at finding B, how do I make (s^2 + 1) = 0
Thanks a lot in advance !
Part 3:
It should be A/(s+1) + (Bs + c)/(s2 + 1)
Hence
2 = A.(s2 + 1) + (Bs +c).(s + 1)
You can then find all the values using s = -1, 0 and 1.
No, (s+4)^2 - 1 = s^2 + 8s + 16 - 1 = s^2 + 8s + 15, you have 17
Note that s^2 + 4s = (s+2)^2 - 4. Does that help?
2/[(s+1)*(s^2 + 1)]
Your setup is wrong, s^2 + 1 has no real roots therefore the proper way to try to split it up is to rewrite it as A/(s+1) + (Bs + C)/(s^2 + 1). Work with that.
1) (s+4)^2 -1 = s^2+8s+16-1 .. but that's not 17?
2) Is s/[(s+4)^2 -1] = sin .. ? You should look at your numerator
NoMoreExams beat me so only look at 2 ..
First it is just wrong as NotStine mentioned. Second, you might want to review some partial fractions. You not always make things equal to 0 .. Use linear algebra
Also if you ARE allowed to use a table, you can use this: http://www.vibrationdata.com/Laplace.htm
i) (s-1)/(s^2 + 8s + 17) = (s-1)/((s + 4)^2 + 1). By equation 2.27, lambda = -1, alpha = 4, beta = 1. So plugging that in we get e^(-4t)[cos(t) - 5sin(t)]
etc.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
