What Is the Correct Way to Calculate Poisson's Ratio?
Poisson's ratio is defined as the ratio of lateral strain to axial strain. In the provided example, with a 5kN compression load, the correct calculation of Poisson's ratio involves using a negative value for the change in height due to compression. The accurate formula is ((2/30) / (-5/100)) * -1, resulting in a Poisson's ratio of 1.4. This reflects the standard convention where tension is positive and compression is negative.
  • Understanding of basic mechanics of materials
  • Familiarity with strain concepts
  • Knowledge of load types (tension and compression)
  • Basic mathematical skills for ratio calculations
  • Study the mechanics of materials, focusing on strain and stress relationships
  • Learn about the significance of Poisson's ratio in material science
  • Explore examples of calculating Poisson's ratio in different loading conditions
  • Investigate the implications of negative and positive strains in engineering applications
Mechanical engineers, materials scientists, and students studying mechanics of materials will benefit from this discussion on Poisson's ratio and its calculation in the context of compressive loads.
tomtomtom1
Hello all
I was hoping someone could help clarify Poissons ratio.
I understand that it is Lateral Strain / Axial Strain but I wanted to understand it in the context of an example.
The question is:-
At 5kN compression load
Original Depth = 30mm
Change in Depth = 2mm
Original Height = 100mm
Change in height= 5mm
I would calculate Poissons ratio by doing the following:-
((2/30) / (5/100))*-1 = -1.4
However I have been told that this is wrong and the correct answer should be:-
((2/30) / (-5/100))*-1 = 1.4
Why is it -5?
I am assuming that the height was reduced by 5mm due to the compression then this is what makes it a negative is this correct?
Thank you.
The standard convention is that tension loads are positive and compressive loads are negative.
