Help with rewriting a compound inequality
  • Context: Undergrad
  • Thread starter Thread starter Andrea94
    Inequality Optimization
The discussion revolves around rewriting a compound inequality and understanding the implications of integer-convex functions in relation to inequalities. Participants explore various approaches to manipulate the inequalities and clarify the concept of integer-convexity.
  • Some participants suggest breaking down the compound inequality into two separate inequalities for easier manipulation.
  • There is a question regarding the meaning of integer-convexity and its relation to the expression $$g(k+1) + g(k-1) - 2g(k)$$.
  • One participant notes that the expression can be rewritten as $$\Delta g(k) - \Delta g(k-1)$$, but its relevance is questioned.
  • Another participant points out that for an integer-convex function, the sign of $$\Delta g(k) - \Delta g(k-1)$$ can vary, leading to uncertainty about its implications.
  • There is discussion about the conditions under which $$g(k+1) + g(k-1) - 2g(k)$$ is positive, particularly in the context of optimal values of $$k$$.
  • Some participants express confusion about the introduction of the term 'optimal' and its relevance to the current discussion.
  • One participant confirms that for a convex function, the second derivative is always positive, which relates to the expression in question.
Participants express differing views on the implications of integer-convexity and the relevance of optimal values, indicating that multiple competing views remain. The discussion does not reach a consensus on the interpretation of the expressions involved.
There are limitations in the discussion regarding the assumptions made about the context of 'optimal' and the definitions of integer-convexity, which are not fully resolved.
Andrea94
TL;DR
Help with rewriting optimality conditions for integer-convex functions.
See attached screenshot.
Stumped on this, I'll take anything at this point (hints, solution, etc).
Mathematics news on Phys.org
Big problems are to be split into smaller problems. You have two inequalities. Write the first one down and manipulate ! Then idem number two.
And: what does integer-convex mean for e.g. $$g(k+1) + g(k-1) - 2g(k) \quad \textsf{?} $$
Great, thanks! Didn't even think about the fact that I could do each inequality separately.
What do you mean? The expression you've written is the same thing as $$\Delta g(k) - \Delta g(k-1)$$ but I'm not sure how that is relevant.
Right, but ##\Delta g(k) - \Delta g(k-1)## can be ##\ge 0## or ##\le 0## for an integer-convex function ... whereas ... :wink:
Still not sure what I'm supposed to see here 😅
The problem with inequalities is that you can only multiply (or divide) left and right with something positive. As it happens, for integer-convex functions the sign of ##g(k+1) + g(k-1) - 2g(k)## is ...
Hm, the only thing I can think of is that if ##k## is optimal and nonzero, then ##g(k+1) + g(k-1) - 2g(k)## is always positive since for optimal ##k## we have ##\Delta g(k) > 0## and ##\Delta g(k-1) < 0##. Is this what you mean?
Not sure where your 'optimal' comes from (it seems to live in your context, but not in the context of this thread ?).
But: yes, for a convex function the second derivative is always positive and so is this ##g(k+1) + g(k-1) - 2g(k)##.
I figured it might help in manipulating the inequalities ...
Ohh I see, thanks a lot for the help!
  • · Replies 26 ·
