Help with right hand rule directions
30 replies · 5K views
minimario
Right Hand Rule
I can get the magnitude, but cannot get the directions from the RHR. Can somebody make video/explain?
Thanks!
minimario said:
Right Hand Rule
Thanks!
Can you post a sketch and your work please? That will help us help you figure this out. Thanks.
It is just the right hand rule...what "sketch" is there?
The problem statement involves a 3-dimensional problem. The solution involves a sketch with 3-d coordinates and calculations. Are you asking us to reproduce all of your work in order to help you? Please post your detailed sketch and calculations so that we can help you.
I don't need the magnitude part. I need the direction part... and 3d coordinates are not needed, the right hand rule is.
You are not helping. I'm out. Hopefully somebody else can help you.
Quote the right hand rule, as it applies to a moving charge in a magnetic field.
Alternatively, quote the equation as a cross product and quote the rule as it relates to cross products.
I think you need a refresher on the right hand rule. You may find the first sentence useful.
http://en.wikipedia.org/wiki/Right-hand_rule
The right-hand rule is defined for use in 3D coordinates. Furthermore, you should generally begin any physics problem by defining a convenient set of coordinates.
Right hand rule: point thumb in direction of v, fingers in direction of B, then F is direction of palm.
I cannot get the direction.. do you have a picture of your right hand?
I meant, in the position of this problem, with thumb, fingers oriented in position
So point your right thumb in the direction of the current (which way is that?) and your fingers in the direction of the field (which way is that?)
minimario said:
I cannot bend my hand so far...
At least answer my questions about directions, or I too will quit the thread. You are not trying very hard to help others help you.
Oh, I already know those ones, it's trivial. Current goes toward east, magnetic field is 75 degrees below horizontal...
... but what direction is the magnetic field geographically?
minimario said:
South
So point your thumb E, your fingers S and 75 degrees down, with your hand flat. Which way is your palm facing?
No, it's not right, according to the answer key: answer says 15 degrees above horizontal in the north south plane
Ah yes, I slipped up.
The direction of Earth's magnetic field is towards the North. That's the way the North pole of a magnetic compass points. This means that considering the Earth as a magnet, its North pole is in the geographic South. Confusing isn't it?
It's 75 degrees below horizontal, so why is it north instead of south?
