Help with standing waves question
A loudspeaker emitting a frequency of 425 Hz creates a standing wave in a glass tube filled with water, where a 20 cm drop in water level corresponds to the formation of a standing wave. The relationship v = fλ is used to calculate the wavelength, leading to the conclusion that λ must be 80 cm based on the fundamental frequency. The discussion clarifies that the 20 cm measurement indicates the first harmonic, as shorter lengths would resonate at higher harmonics. It emphasizes that the standing wave's formation at this specific length confirms it is the fundamental frequency. Understanding these principles is crucial for accurately interpreting wave behavior in closed tubes.
Vandalus
A small loudspeaker connected to a signal generator emits a sound of frequency 425 Hz. It is fixed above a long glass tube that is filled with water and has a drain at the bottom so that the water can be slowly released from it. When the level has fallen 20cm from the top of the tube, a standing wave is formed and the air column resonates.
Calculate the wavelength of the sound.
v = fλ
In my book's worked example it says that:
λ/4 = 20cm therefore the λ must be 80cm.
What I don't understand is this:
How do you know that at 20 cm, the standing wave generated will definitely be the first harmonic/fundamental frequency since λ/4 only applies if the standing wave generated is the fundamental frequency?
Isn't 20cm just an arbitrary number?
Or is it that no matter how much the water level falls (no matter the length of the closed tube) the first input of sound will definitely be the fundamental frequency?
Any help is greatly appreciated :D
Yes. It's the (implied) fact that it did not resonate at any shorter length. Had 20cm been, say, the third harmonic, it would have resonated at 4cm.
Ah ok. Looks like I should learn to read questions more thoroughly aha.
Thanks :D
