Hertz contact problems of three cylinders
The discussion revolves around calculating the force applied by an upper roller in a Hertz contact problem involving three cylinders. Participants explore the calculations related to contact surfaces and angles, addressing discrepancies in solutions and assumptions related to the problem.
  • Homework-related
  • One participant presents a calculation for the normal force (FR1) and notes a discrepancy between their result and the provided solution.
  • Another participant questions the definition of a variable "L" that is not clear in the context of the problem.
  • A participant clarifies that certain variables are set to zero for the sake of student assignments, which may have caused confusion.
  • There is a discussion about the calculation of an angle using an isosceles triangle, with one participant providing their method and results.
  • Concerns are raised about potential discrepancies in the solution due to factors like deformation or friction at contact points, with some suggesting that the problem assumes ideal conditions.
  • One participant expresses agreement with the calculations of others and suggests that the provided answer may have been incorrect due to a possible error in the numbers given by the professor.
  • A later update indicates that the original solution was indeed correct, attributing the confusion to an error in the numbers provided by the professor.
Participants express differing views on the correctness of the calculations and the assumptions made in the problem. While some agree on the calculations leading to a specific force value, others question the assumptions and the potential for errors in the provided solution.
Participants note several assumptions, including zero deflection of rollers, zero friction, and the absence of hidden complexities in the problem. These assumptions may limit the applicability of the calculations presented.
Amaelle
look at the image
hertz contact
Greetings
i´m trying to find the Force applied by the upper roller to calculate the contact surface.
Here is indeed my solution
2*FR1* cos31,38=F=1500N
FR1=878,57N (which is wrong the correct solution says 818,1N)
FR1 is the force normal to the surface of contact.
any help would highly appreciated
thank you!
Sorry, I'm not seeing where "L" is defined...
Sorry L and S are equal to 0 , it was for the students so that each one do a different assignment sorry for the confusion :)
Amaelle said:
Homework Statement:: look at the image
Relevant Equations:: hertz contact
cos31,38
In that case, I get a different value for that angle. Can you show your calculation for how you solved for it?
Thank you here it is
we have an isoscele triangle
as you can see the first side is the some of the R1+R2=48
I got the other side by Pythagore
48^2-25^2=1679 means the side value is 40,97
and then the angle =invers.tangente(25/40,97) =31,38°
thank you!
Oh, I see now that I misread this as c = 25 + 5. But if that is "S" and not "5", then I get the same angle as you. I'm not sure where the discrepancy is in your solution then...
thank you for taking time to answer me!
Could it have something to do with slight deformation or friction at the contact points? If they are infinitely hard and frictionless surfaces I think your answer is correct. But since they give so much other information... What chapter is this out of in the book? Do they discuss any other factors that would affect this calculation in that part of the text?
Indeed one of the asymptions is the absence of frictions, indeed I'm surprised as you because this is an undergrad course so there shouldn't be any hidden tricks :oldconfused:
Realistic assumptions, given the material properties and that this is an undergrad problem:
Zero deflection of rollers due to Hertz contact stress
Zero deflection in bearings
Zero friction
No hidden tricks
I get exactly the same contact force as the OP - 878.57 N.
I agree with the calculations by both @Amaelle and @berkeman, and have no idea where the given answer came from. I can only guess that somebody entered a number wrong.
just an update! the solution was correct it was the Professor mistake to give wrong numbers
Thanks a million guys!
  • Haha
  • · Replies 20 ·
  • · Replies 21 ·
