How Do HEU and LEU Reactors Differ in Performance and Cost?
High-enriched uranium (HEU) reactors, such as the S8G used in Ohio-class submarines, weigh approximately 2750 tons and produce 60,000 horsepower with a fuel endurance of 9 years. In contrast, low-enriched uranium (LEU) reactors require more frequent fuel replacements, approximately 2 to 3 times more often, but are cheaper to manufacture, needing only 7 separative work units (SWU) compared to 230 SWU for HEU. While HEU reactors are designed for compactness and high performance per mass, LEU reactors are typically larger and optimized for different operational goals, producing significantly higher power outputs in commercial applications, ranging from 900 MWe to 1200 MWe. The discussion highlights the complexities in comparing reactor performance due to differing design objectives and fuel management practices.
  • Understanding of HEU and LEU reactor designs
  • Knowledge of fission reactor performance metrics
  • Familiarity with nuclear fuel cycles and management
  • Basic principles of power conversion systems (e.g., Rankine and Brayton cycles)
  • Research the specifications and performance of the S8G HEU reactor
  • Investigate the fuel management practices for commercial LEU reactors
  • Study the design and performance of civilian nuclear ships like the NS Savannah
  • Explore the characteristics of nuclear rocket cores such as Kiwi and Nerva
Nuclear engineers, military strategists, game designers, and anyone interested in the comparative performance and cost of fission reactors.
Marasmusine
Summary:: How do high-enriched uranium reactors compare with low-enriched uranium reactors?
Hello, I'm doing some research for a book, and there's some information about fission reactors I just can't find.
I am comparing HEU fission reactors with LEU fission reactors ... even ballpark figures will be helpful.
So for example, the S8G HEU reactor used on the Ohio-class submarines weighed 2750 tons (including shielding, coolant and turbines, I think, correct me if I'm wrong). It produced 60,000 hp for the driveshaft. The fuel endurance was 9 years.
What would be the performance of a LEU reactor of a similar mass? From what I've read, the fuel would need replacing 2 to 3 times more often. But I think LEU would be cheaper to manufacture (7 SWU instead of 230 SWU).
Performace per mass of the whole reactor is of most interest to me.
Thanks for reading, apologies if it is an inappropriate question, this is my first post.
Difficult question, not only because there are no commercial reactors that are comparable in terms of size afaik.
Most LEU reactors are much bigger than the S8G and I do not think that performance per mass was ever a target parameter for LEUs, whereas it well should be for a vessel that needs to minimize mass to maximize boat performance.
So the design goal are entirely different, which further distorts the answer, perhaps totally.
HEU reactors are smaller, hence the need for HEU. Commercial power reactors are much larger and produce greater power levels. One mentions 60,000 shp marine power plant, or 45 MW, so let's use that number for comparison to commercial power reactors.
Large commercial power reactors produce ~900 MWe - 1200 MWe, so about 20 to 27 times larger. One has to look at individual reactors that produce more power. A 900 MWe reactor has a fuel inventory of ~72-73 tU (81.7 - 82.8 tUO2), and larger 1100-1200 MWe reactor would have ~82-88 MTU (92 - 100 tUO2), depending on fuel pellet diameter, pellet density, and whether or not the low enrichment blankets have annular or solid pellets. Many commercial power reactors in the US have been uprated to generate more power from the original design license.
Fuel management and fuel cycles have changed over the decades. LWR fuel was originally intended for 3 or 4 years on annual cycles (with third core or quarter core reload batches) and subsequently reprocessed/recycled. When reprocessing disappeared as an option in the US, fuel cycles were extended to 18 to 24 months, and fuel batch sizes were increased to nearly half-core in some cases.
There is no such thing as a typical power reactor, even those in the same design class, since basically every reactor is custom designed.
Likes Marasmusine
That's a very strange interest. Why?
It's nothing important or academic I'm afraid!
It's for an role-playing game supplement I'm writing, to allow the design of vehicles. To simply the design process, vehicles are broken down into 20 components of equal mass. So that Ohio-class submarine will have 3 components of "HEU Fission Reactor Plant" providing X amount of power to 1 "Shrouded Screw Propeller" component.
This system has given me fairly accurate vehicle speeds for things like gas-turbine powered helicopters and sailing ships.
I can look to civilian nuclear ships such as the NS Savannah but I can't always find the numbers I need for the mass of the fission plant.
Astronuc's reply has given me more confidence in just making these numbers up :)
The numbers for the NS Savannah reactor can be found in a Wikipedia article on the ship,
https://en.wikipedia.org/wiki/NS_Savannah#Reactor
Note, the ship's power plant was designed for 20,000 horsepower (15 MW), as compared to a vehicle like a HMMWV with a power level about 190 hp (140 kW). One would need a small reactor, and assume a metal fuel, for compactness. Enrichment would not significantly affect the mass because U-235 is only 1% less mass than U-238. One has to decide on a power conversion cycle, e.g., steam (Rankine) or gas (Brayton). One might wish to look at nuclear rocket cores, e.g., Kiwi, Nerva or Phoebus.
See - https://en.wikipedia.org/wiki/Project_Rover
Power conversion systems and shielding add large masses.
Likes Marasmusine
Recently, I’ve heard from Anton Petrov on YouTube that some tidally-locked planets around red-dwarf stars (such as TRAPPIST-1) have been suspected to flip around their own axis every once in a while — so that the former day side becomes the night side, and vice versa. This is presumed to happen for the same reason as why a T handle set in a rotating motion on a space station starts flipping back and forth. The latter is an issue we discussed for spaceship designs, when it came to how...
  • · Replies 46 ·
15K
