Abstractness said:
Take a look at aerospike engines, they're not too bad compared with classical rockets.
Yeah, but they are combusting their materials inside a combustion chamber to keep that reaction contained and then exhausting the resulting gas over a concave surface where the pressure gradient will keep the flow attached to the surface and direct the flow in the direction of thrust. Yours combusts externally where much of the energy of combustion may be lost in other directions and then those gases traverse a convex surface where flow separation is quite possible, letting more momentum escape vertically before it can be redirected horizontally.
Abstractness said:
I guess that depends on a lot of variables like the exact shape of the aircraft, speed, altitude, fuel type, fuel temperature, amount of injected fuel.
To have more control over when combustion happens, one could place small bumps on the surface at the right places, which produce small "turbulences" to mix the fuel and air faster.
You aren't entirely off-base here, but small bumps won't do the trick for you. It is extraordinarily difficult to trip a hypersonic boundary layer. This isn't a golf ball or a 747. For example, the scramjet used on the X-43 required giant ramp-shaped boundary layer trips to try and induce turbulence prior to the engine intake and used a series of reflected shocks to further compress and slow the flow entering the combustor to allow it time to combust and even that was only partially successful. Your design cannot utilize reflected shocks of any sort, and to slow the flow down substantially to help you out using simply the conical shock coming from the tip, you would need to have a larger half-angle on the tip, which would quickly become prohibitive in terms of wave drag at the Mach numbers you are proposing.
Abstractness said:
The advantage here is that the fuel is spread over the entire circumference of the aircraft.
This means the area of contact between the fuel and air is much bigger, hence it would combust much faster, right ?
Not really. The keys are getting the fuel and air well-mixed and then having the flow moving slow enough that the combustion reaction will occur in a region where it is still useful (i.e. before the flow is re-expanded). Having it well-mixed will help speed the reaction along, but it only buys you so much since the reaction still occurs at a finite rate. Creating that mixture is very difficult to begin with and is one of the chief challenges in current scramjet technology. Your plan essentially puts fuel into the lower levels of a laminar boundary layer, meaning it isn't going to mix almost at all as long as that boundary layer is laminar, and on a smooth surface at Mach 10, it will likely be laminar for a very large portion of the body.
You can add boundary layer trips as are used on scramjet vehicles now (not an easy challenge in and of itself), but that raises other problems. These would need to be located very near the tip of the vehicle (or even be part of the fuel injector) so as to maximize the distance along the body where you have turbulent flow. Unfortunately, this is also the hottest part of the body where the flow is compressed across the shock and then adiabatically brought to rest. At 100,000 feet, it would be hot to the tune of some 4600 K, hot enough to absolutely destroy these trips you would hypothetically need (and most other materials used in typical aircraft).
Abstractness said:
Wouldn't the evaporated fuel inside the tank (gas) would provide enough pressure?
Here's a similar technique for rockets: http://en.wikipedia.org/wiki/Pressure-fed_cycle_(rocket )
It could perhaps provide some of that pressure, but remember that the gases and fuel in a rocket engine are combusting and exiting out the rear of the rocket and not having to fight against the pressure at the tip of the rocket, only the static pressure outside the nozzle which is substantially lower. For grins, let's assume that you are flying this thing at 100,000 ft altitude. The pressure at the tip of your vehicle would be some 20.6 psi (142 kPa) absolute. That's not so bad.
I assume that your vehicle would need to make it up to that altitude though, so let's look at say 50,000 feet, the maximum service ceiling at which a B-52 could fly, which usually would launch a vehicle of this sort where it would be launched. The pressure at the tip of the vehicle would then reach roughly 225 psi (1550 kPa) absolute. That is getting pretty substantial. Maybe your fuel being heated would be able to overcome this, maybe not. If you want to launch this at sea level, the pressure is now 1,900 psi (13 MPa). This would be nearly impossible to generate I would think.
So yes, you may be able to get it to work at one set of altitudes, but what happens then if you try and change altitudes? If you are relying solely on the fuel pressure, you might imagine flying at 100,000 feet, and having a fuel pressure from heating that is just enough to eject the fuel, but then when it comes down to 50,000 ft it is no longer sufficient. Or go the other direction and now your vehicle is spewing out so much fuel from the tip that you lose a lot of it. You need some way to control the pressure. A pressure regulator could help if one exists for such high temperatures, but then you have no means of pressure relief in your tank since it is going to continually get hotter until either the tank melts, the fuel runs out of the tank bursts from the built-up pressure.
Plain and simple, it might work but you would need to do a pretty substantial amount of engineering work to make it work. One thing that would certainly help is to just not expel the fuel from the tip and do it somewhere slightly downstream in a fashion that it is injected into the flow at an angle that gives it some pre-existing momentum in the direction of the flow (sort of a wall-parallel injector). That would help lower the required pressure and keep you from losing a lot of fuel and give you a more even fuel mix around the azimuth of the vehicle.
Abstractness said:
We could use the pressure of the flames outside to counteract the pressure inside the tank, so we don't have to use a thick walled tank.
This doesn't really make sense for two reasons. For one, even if the pressure of the combustion region was enough to counteract the internal pressure of the tank, using a thin-wall tank would lead to thermal failure very quickly. Either the tank would melt or weaken to the point of rupture due to internal pressure since the internal pressure would continue to go up while the flame pressure would remain constant.
The second reason is more fundamental. Your tank is in a region where the flow is going to be rapidly expanding, meaning that the pressure in that part of your flow is going to be extraordinarily low to begin with. Depending on your altitude and the nature of the combustion, it may even be a lower pressure than the surrounding atmosphere.
You could maybe take a cue from rocket designers and cool the surface with the fuel, but you can't do it in the fashion you propose where you use the entire fuel reservoir as the heat sink. The pressure would just get way too high most likely. When they cool rocket nozzles with fuel, they do it by pumping the fuel in coils around the nozzle to cool it down and then the resultant heating of the fuel, by the time it reaches the combustion chamber, has caused it to evaporate and increase in pressure in a constructive way. That heat never finds its way back into the fuel reservoir, and if it did it would be potentially quite catastrophic. You will grapple with that same challenge here, meaning your tank needs to be smaller relative to the body and well-insulated from the heat.
Finally, what about controlling this vehicle? If it is axisymmetric and shrouded in flame, it would be quite difficult to use any sort of control surfaces that would survive very long.
