Calculating Torque and Rotational Kinetic Energy: Homework Help
  • Thread starter Thread starter vitaly
    Homework
The discussion focuses on two physics problems involving torque and rotational kinetic energy. For the first problem, participants confirm the calculations for torque produced by forces of 4 N and 9 N, which yield 1.2 N*m counterclockwise and 2.7 N*m clockwise, respectively. To solve for torque when the force is not perpendicular, it is suggested to use the component of the force that is perpendicular to the radius. In the second problem, the moment of inertia is correctly calculated as 0.96 kg*m^2, and the formula for rotational kinetic energy is provided as 1/2 I ω^2, where ω is the angular speed in radians per second. Overall, the thread provides guidance on solving torque and rotational kinetic energy problems in physics.
vitaly
I need some help with these two problems:
1. A wheel of radius 30 cm has forces applied to it as shown in the figure below. Find the torque produced by the force of (a) 4 N (b) 9 N (c) 7 N (d) 6 N. See attachment for figure.
(a) = _____1.2 N*m_____ counterclockwise?
(b) = _____2.7 N*m_____ clockwise?
(c) = __________ N*m
(d) = __________ N*m clockwise
For a, I did: (4N)(.3 M ) = 1.2 N*m
for b, (9 N)(.3 M) = 2.7 N*m
for c, I don't know how to solve it if hte force isn't perpendicular.
for d, same as c. Does anybody know how to solve for c and d, and does anybody know if a and b are correct?
2. A wheel, of mass 6 Kg and radius of gyration 40 cm, is rotating at 300 rpm. Find its momentum of inertia and its rotational KE.
I got:
I = mr^2 = (6 Kg)(0.4 m)^2 = 0.96 kg*m^2. Is that right?
And I'm not sure how to find the rotational kinetic energy. Is there an equation I need?
All help is appreciated. thank you
For the second,what is the moment of inertia of a disk...?
Daniel.
ke
rotational KE is given by 1/2* I * (w^2)
where I is moment of inertia and w is the angular velocity...
wiz
Radius of Gyration does not equal the radius of the disk. You will have to find an equation relating mass, Moment of Intertia, and Radius of Gyration. Hint: It involves a division sign and a square root. From there, it is easy to find your Moment of Interia.
To find the rotational interia, it is basically the same equation for linear, but with circular definitions in. (i.e. rad/s instead of m/s, angular velocity instead of linear velocity)
Good.
When the force is not perpendicular to the radius, find the component of the force perpendicular to the radius. (Hint: F sin\theta, where \theta is the angle that the force makes with the radius.)
a and b are correct.
I got:
This is correct.
{KE}_{rot} = 1/2 I \omega^2
where \omega is the angular speed (measured in radians/sec).
  • · Replies 21 ·
  • · Replies 95 ·
