How Does Charge Redistribute When Capacitors Are Connected in Series?
  • Thread starter Thread starter xxkylexx
    Capacitors
When capacitors C1 (4.0 µF) and C2 (2.0 µF) are connected in series across a 95 V battery, they initially store charges of 380 µC and 190 µC, respectively. Upon disconnection from the battery and reconfiguration with positive plates connected together, the equivalent capacitance is calculated as 4/3 µF. The total charge remains conserved, leading to a redistribution of charge between the capacitors, which requires further calculation to determine the final charge on each capacitor.
  • Understanding of capacitor charge and voltage relationships (Q = CV)
  • Knowledge of series and parallel capacitor configurations
  • Familiarity with equivalent capacitance calculations (1/Ceq = 1/C1 + 1/C2)
  • Basic principles of charge conservation in electrical circuits
  • Calculate the final charge on capacitors after reconfiguration using charge conservation principles
  • Explore the effects of different capacitance values on charge distribution in series connections
  • Learn about energy storage in capacitors and how it changes with configuration
  • Investigate practical applications of series and parallel capacitor configurations in electronic circuits
Students and professionals in electrical engineering, physics enthusiasts, and anyone studying capacitor behavior in circuit design.
xxkylexx
1. Capacitors C1 = 4.0 µF and C2 = 2.0 µF are charged as a series combination across a 95 V battery. The two capacitors are disconnected from the battery and from each other. They are then connected positive plate to positive plate and negative plate to negative plate. Calculate the resulting charge on each capacitor. ___ µC (C1)
___ µC (C2)
2. Q = CV , 1/Ceq = 1/C1 + 1/C2
3. First, I calculated the charge on each capacitor while they were in series connected to the battery-- Which is 380 and 190, respectively. I then calculated the equivalent capacitance to be 4/3, and think that Q1 + Q2 (the charge after they are hooked together) should equal 380, but I can't ever seem to get a correct answer. I know how to solve this if they are in parallel, but this series configuration is screwing me up.Any help is appreciated.Thanks so much,
Kyle
Anyone able to assist with this one?
  • · Replies 18 ·
