Solving sqrt(x)+y=11 and x+sqrt(y)=7 without quartic polynomials
5 replies · 7K views
benf.stokes
Hi
How do you solve this equations analyticaly without solving a 4th degree polynomial
sqrt(x)+y=11; x+sqrt(y)=7
Thanks
Mathematics news on Phys.org
I'll give a general outline on how to solve this:
First of all, use new variables. a = sqrt(x) and b = sqrt(y). That will remove those ugly square roots for now.
Then, add the 2 equations and form a new equation a + a² + b + b² = 18. In this equation, 18 can be split up into 2 unknown values c and d to form 2 quadratic equations. Of these 2 values, you only need to know 1 to calculate the other, that is d = 18 - c. The roots of these 2 quadratic equations can be written in terms of these 2 values. Keeping in mind that the solutions can only be positive, that should lead you to the right answer
I may be misunderstanding but you seem to be saying that if you have [itex]a+ a^2+ b+ b^2= 18= c+ d[/itex] then you must have [itex]a+ a^2= c[/itex] and [itex]b+ b^2= d[/itex]. That is not true.
HallsofIvy said:
I may be misunderstanding but you seem to be saying that is you have [itex]a+ a^2+ b+ b^2= 18= c+ d[/itex] then you must have [itex]a+ a^2= c[/itex] and [itex]b+ b^2= d[/itex]. That is not true.
Do u want to explain why this is not true? If I define c as being a+a², and d as being b+b², then a + a² + b + b² = c + d = 18
Edit: nvm, you probably did misunderstand me^^
can you plees put full steps for this equation plees
Hello I'm 14 years old so i don't know what a 4th degree polynomial is... however i agree with the guy named Kyouran. This is how i did it:
sqrt(x) + y = 11 ...(1)
sqrt(y) + x = 7 ...(2)
Let sqrt(x) = a, and sqrt(y) = b.
The eqs will then be:
a + b^2 = 11 ...(3)
b + a^2 = 7 ...(4)
Add them together and you get:
a + a^2 + b + b^2 = 18
The way i solved it is just by doing guess and check. This only takes common sense:
I first tried a = 2 and b = 3 which when substituted into the equation equals 18:
2 + 2^2 + 3 + 3^2 = 18
However when subbing them into eqs 3 and 4, they weren't correct:
So i then switched the values around saying a = 3, and b = 2 which when subbed into eqs 3 and 4 were correct!
And so, as said before...
Since I let sqrt(x) = a, and the sqrt(y) = b:
sqrt (x) = 3
and so therefore x = 9
sqrt (y) = 2
and so therefore y = 4
therefore x = 9, y = 4 ;)
Now you will find, that when subbing these x and y values into your original eqs (1) and (2), they are sure to be correct!
