I think you're right. I'll try to be more careful.
The discussion centers on calculating the total horizontal force exerted on one side of a square tank filled with water. The tank has a height of 12 feet and a perimeter of 40 feet, leading to a side length of 10 feet. The correct calculation for the horizontal force is derived from integrating the pressure at various depths, resulting in a total force of approximately 45,000 pounds, as confirmed by the participants. The pressure at any depth is calculated using the formula 62.4y, where y represents the depth in feet.
  • Understanding of fluid mechanics principles, specifically hydrostatic pressure.
  • Familiarity with integration techniques in calculus.
  • Knowledge of the English system of units, particularly pounds as a measure of force.
  • Ability to calculate area and volume of geometric shapes, specifically squares.
  • Study hydrostatic pressure calculations in fluid mechanics.
  • Learn integration techniques for calculating forces in fluid systems.
  • Review the English system of units, focusing on the relationship between mass and force.
  • Explore applications of pressure calculations in civil engineering contexts.
Civil engineers, students preparing for state civil service exams, and anyone interested in fluid mechanics and pressure calculations in engineering applications.
jbowers9
A square tank 12 feet high having a perimeter of 40 feet is filled with water weighing 62.4 pounds per cubic foot. The total horizontal force on one side of the tank due to the water pressure is MOST NEARLY ________ pounds.
A. 58,000
B. 45,000
C. 36,000
D. 13,000
The answer key says 45,000 lbs. is the answer but I have no clue how they got there.
Total pressure - lbs./ft^2 - should be 12 x 62.4, or 5.2lbs/in^2. How do they get 45,000?
First: what is the volume of the tank? Note that 40 feet is the perimeter. Secondly, how do you calculate the horizontal force given the volume of water and the weight (look in your textbook or lecture notes)
Square Tank
with perimeter 40 feet. So each side is 10 feet. I really am mildly ashamed to admit that I don't recall a formula for "horizontal" pressure. I thought pressure at the same depth was the same throughout a fluid. This question is for a State Civile Service exam. NY State. Maybe we do things differently.
Hi jbowers9! :smile:
Yes, pressure is the same in all directions at any fixed height.
Hint: force = pressure times area.
And how does the pressure change with the depth? :smile:
Horizontal Pressure
OK
So the area of the tank is 100ft^2...
It's 12 ft high...
62.4 x 10 X 10 X 12 gives total force which is not 45,000 lbs.
jbowers9 said:
OK
It's 12 ft high...
urgh!
That's the mass! :cry:
HINT:
Horizontal "Force"
Actually, the density x volume IS the force in the English system. Lbs. is a measure of force (mass x g). The English system of mass is the slug.
I figured it out Saturday evening. 62.4y - if y is the vertical coordinate - is the PRESSURE at any depth y in the tank (lbs/ft^2). 10dy is an element of area along one side of the tank.
642 y dy integrated over the limits 0 - 12 give 642 x 72 = 46,224 which is close enough to the given answer of 45,000 for me. Notice that the dimension of the answer is pounds. Which is a unit of FORCE in the English system. Thank you.
I did know that! :smile:
But the mass (in pounds) is a vertical force, and you were asked for the horizontal force! :rolleyes:
erm … I think you'd get a lot closer if you used 624 instead of 642. :smile:
20K
