Horn Antenna Radio Interferometer
An experiment involving a horn antenna radio interferometer has been conducted using two metal funnels connected by copper tubing, with a distance of 600mm between their centers. The setup includes an LNB connected to a voltage data logger via a satellite finder, although software issues are present. The experiment aims to determine if the configuration will function as intended and to understand the underlying principles, particularly regarding signal detection and calibration. Observations indicate that the setup successfully detects interference fringes and produces patterns similar to those from a parabolic dish when sweeping the sky. The discussion seeks equations relating the intensity of electromagnetic radiation to the dimensions and angles of the horns to further analyze the results.
rattis
This is a strange experiment (or not so compared to some of the experiments I've done) that I am currently undertaking, and require your help.
I have built an interferometer of sorts. Two metal funnels of diameter 200mm are attached together by copper tubing (20mm?) through a Y junction with all angles of 120 degrees. The distance between the centre of the funnels is 600mm. The lower tube connects directly into an LNB.
I am trying to connect the LNB to a voltage data logger via a device called a satellite finder that is basically an analogue dial voltmeter. Currently the software isn't working, but it should do the job.
What I need your help with.
I don't know if it (what ever it is) will work, and if it does, why? I can't find any (seemingly) relevant equations.
Unless there is some sort of mixer in the Y junction you haven't built an interferometer.
It sounds like you are trying to make a directional signal detector.
I would have thought you want to connect a LNB to each funnel and measure the relative signal strength of each.
You will have to do some caibration because the Feed+LNBs are unlikely to be perfectly equal gains and sensitivity.
Got this setup and it actually works! One can see some excellent fringes when a person walks past it, and there's certainly some stuff going on when a sweep of the sky is made.
can anyone give me an equation relating the intensity of the em radiation detected and the size/angle of the horns? Or just some general electrostatics relations
If anyone is interested, it works exceptionally well. Interference fringes are observed, and when sweeping the southern horizon, a pattern that is significantly similar to that obtained with a standard parabolic reflective dish is observed.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
