- 2,244
It's not a matter of one factor dominating over another (at least not for this question). Rearrangements will happen, and stereochemical effects will happen. I unfortunately didn't think of rearrangements when I initially answered your question, but Ygggdrasil did, and his answer was therefore on the money. If you consider only rearrangements, then c will be the correct answer. If you consider rearrangements and stereochemistry, c is still correct, assuming that you start with a racemic mixture of c. If you assume that you start with one enantiomer of c, then there is no correct answer (SN1 and SN2 give different compunds in every case).HPPAS said:But is there a general rule so as to decide which factor dominates under what conditions?
