How can boundary conditions be written for a DEQ with Dirac delta?
The discussion focuses on solving the differential equation (DEQ) f''[x] = f[x] DiracDelta[x - a] - b with Robin boundary conditions f'[0] == f[0] and f'[c] == f[c]. The problem arises in the context of a 1D diffusion system with homogeneous generation and a point scatterer at x=a. Participants suggest that the DEQ can be viewed as two coupled DEQs defined on intervals [0,a] and [a,c], with shared Robin boundary conditions that complicate the separation of the equations.
  • Understanding of differential equations, specifically second-order DEQs.
  • Familiarity with Dirac delta functions and their applications in modeling point sources.
  • Knowledge of boundary conditions, particularly Robin boundary conditions.
  • Experience with Laplace transforms and their use in solving DEQs.
  • Research methods for solving coupled differential equations with Robin boundary conditions.
  • Study the application of Dirac delta functions in differential equations and their impact on boundary conditions.
  • Learn techniques for integrating differential equations over specific intervals to derive boundary conditions.
  • Explore numerical methods for solving 1D diffusion equations with point sources and homogeneous generation.
Mathematicians, physicists, and engineers working on diffusion processes, particularly those dealing with boundary value problems and point sources in steady-state conditions.
rynlee
Hi All,
so I'm trying to tackle this DEQ:
f''[x] = f[x] DiracDelta[x - a] - b,
with robin boundary conditions
f'[0] == f[0], f'[c] == f[c]
where a,b, and c are constants.
If you're curious, I'm getting this because I'm trying to treat steady state in a 1D diffusion system where I have homogenous generation along the length (b, in 1/(length-time) units), f(x) is the population distribution, and I have a point scatterer at x=a consuming population at a rate proportional to the concentration there (f(x)). i.e.
f=f(x,t)
df/dt = D*(d^2/dx^2)f + b - f*DiracDelta(x-a) = 0
I tried to take a laplace transform approach but couldn't hack it, if someone has another idea on how to approach this I'd appreciate it!
Thanks!
Properly I should title this more like
"diffusion-reaction DEQ with delta reaction term in steady state with homogenous generation"
Rynlee,
can you see the geometrical meaning of your ODE in a small neighborhood of a? Do you understand why you have 4 BCs for a second order ODE?
don't I have 2 BCs in a second order DEQ?
If you stick with the original 2D problem I have 2BCs (those) and in the steady state assumption no longer need an initial conditions since I eliminate t, leaving me with the 2nd order DEQ and two robin BCs.
For a simpler problem Neumann BCs could be taken,
f'[0] == 0, f'[c]==0
But the difficulty remains.
You are right, I misinterpreted your statements. Hint: you have two problems, one before and one after a. Do you know how to handle them?
That's a good point, really this could be viewed as two coupled DEQs, one defined on [0,a] and the other defined on [a,c], each with a set of Robin BCs, with one of them shared (at a).
The two DEQs aren't independent though, since the BCs are Robin not Neumann. If we instead had
f'[0]=f'[a]=f'[c]=0, then I could split this into two DEQs. Since that's not the case though, the distribution on each side of a effects the other side.
Rynlee, you got the point: do you know how to write the BCs in a? Hint: integrate the ODE in [a-delta,a+delta] and compute the limit when delta->0.
  • · Replies 22 ·
