How Can Dynamic EMF Variation Enhance Bone Fracture Healing in Animal Studies?
The discussion centers on the development of a setup to generate dynamic electromagnetic fields (EMF) for studying their effects on bone fracture healing in small animals. Participants explore technical aspects of the setup, including signal generation, coil configuration, and ethical considerations regarding animal research.
  • Ethical considerations
  • One participant describes their setup involving two solenoid coils excited by 15 V AC to generate a static EMF of 200 µT, seeking advice on how to make the EMF dynamic.
  • Another participant questions the use of a 60Hz coil drive, suggesting that higher frequencies might be more effective for bone healing and inquires about previous research on waveform effectiveness.
  • A participant suggests using a pulse generator circuit to achieve a continuously changing EMF, while another discusses the potential use of an LM 324 OPAMP for this purpose.
  • Concerns are raised about the ethical implications of conducting experiments on live animals, with participants discussing the need for compliance with ethical standards and institutional protocols.
  • There is a discussion about the nature of the EM field generated, with one participant clarifying that it is more accurately described as a magnetic field.
  • One participant expresses uncertainty about the discomfort level for animals exposed to a 200 µT field for one hour per day, while another participant raises concerns about the initial act of fracturing bones for the experiment.
Participants do not reach a consensus on the optimal frequency or waveform for the EMF, and there are differing views on the ethical considerations of the research involving live animals. The discussion remains unresolved regarding the best approach to the experimental setup and the ethical implications.
Participants mention the need for specific technical specifications of the coils being used, as well as the importance of understanding the pulse profile and frequency for effective experimentation. Ethical considerations regarding animal welfare and compliance with research regulations are also highlighted.
mit_cool
I am developing a setup to generate dnamic eletromagnetic fields (EMF) which will be used to study the effect of EMF on bone francture healing in small animals.The setup has two solenoid coils which are separated by a distance and connected in series. Both coils are excited by 15 V AC that generated the EMF of 200 µT in the space between the coils. However, I want that the EMF to very between 0-200 µT repeatedly.
Can you tell me what changes I should do in my setup?
Thanks,
MitPulsed electromagnetic field? - ResearchGate. Available from: https://www.researchgate.net/post/Pulsed_electromagnetic_field2 [accessed Jan 16, 2017].
Welcome to the PF. :smile:
That sounds like an interesting research project. It seems like I've seen similar research in the past, but I don't remember where. What signal generation equipment do you have available in your lab? Do you have something like an HP 33120 AFG source available?
That link doesn't take me directly to the paper. Can you provide a direct link please?
BTW, "EMF" traditionally means "Electromagnetic Force", not EM Field. I was a little confused by the way you used the term in your post. :smile:
Thanks. Yes I should use EM field.
First I convert 230 AC to 15 V AC using a stepdown transformer. After that it is directly feeded to the coils which gives me EM field of 200 µT. However I want EM field to be continously changing. For that I am thinking add a small pulse generator circuit between the transformer and coil. The pulse generator looks like this.
http://www.lamja.com/?p=33
Do you think giving 15 ´V AC as an input to this circuit can create ay problem?
Mit
PS: Sorry that RG post got deleted :(
Are you sure you just want to us a 60Hz coil drive? I would think that higher frequencies would be more effective for affecting the bone healing. What types of waveforms have been used in previous research, and how effective have they been?
Do you have access to an electronics lab at school? Or are you just doing this at home for a personal research project? I'd guess you must be part of a lab, if you are going to be doing actual experiments on lab animals.
An instrument like the HP 33120 Arbitrary Function Generator is a good tool for this, since you can program many different types of varying waveforms to be output. Then if you need more power, you just use an amplifier in series with the HP 33120 source...
http://www.sglabs.it/public/SgLabs_HP_33120A_1.JPG
Thanks,
Mit
Actually, I'll go even one step further. What you are generating is not really an "electromagnetic field", but rather simply a "magnetic field", based on the fact that you measure a maximum of 200 μT field.
So it seems that you want to do the same thing that a pulse NMR can do routinely. However, there are a couple of things that puzzles me:
1. What is the pulse profile that you want? You said you want to repeatedly go between 0 - 200 μT, but you didn't describe the time profile of the pulse.
2. Aren't you getting repeated cycle of the magnetic field already? After all, you do have an AC source that, according to you, can get to 200 μT. If you only need the magnetic field to be only in one direction, then maybe rectify the AC current.
Zz.
Square pulses of around 30-50 ms may work. Previos studies actully used same pulse width and frequency like between 10-20 Hz. So I would first like to try what has been used previsouly.
Thanks for the suggestions HP 33120 but I want to integrate the pulse circuit in my coil assembly.
What do you thin about LM 324 OPAMP?
Sorry I am new to EMF field so I might be littlebit stupid speaking.
Thanks,
It's a low-frequency, low-power opamp, but perhaps you could use it in your application.
Another option would be to use your PC's sound card and free software to make a PC-based signal generator. That would give you a lot more flexibility in the waveforms you generate for your experiments. You could make a small power amp for it as well, if it looked like you needed more coil drive power. Just google Free Sound Card Signal Generator Software to see what some of your choices are. :smile:
Many thanks. Just a quick question.
Would you agree when I say, " The EM field generated by exciting coils with AC voltage is always changing since AC voltage is constantly changing".
Thanks,
Mit
Yes, I should think it really would need more power. This would definitely apply if you try to operate the coils at a higher frequency. You need to have some idea of the specification of these coils you are using. If they are for 60Hz operation then they could have iron cores, which would limit the possible operating frequency. There may be markings on the coils, telling you their Inductance value.
PS It is worth asking about the Ethics of the research you are doing. Are the animals in this experiment alive and are they being treated in an acceptable way? I'm not sure of the stance of PF on this sort of research but it is a question that needs to be asked.
Agreed.
Also, depending on where this research is done there may be requirements to comply with university or company policy. I have done some work at a university in the past where any research involving any live animals or people must be approved and monitored by a special committee. It involved explicit written protocols for the experimentation, and documentation to demonstrate compliance with established safety standards / regulations, etc.
Jason
Many thanks for valuable suggestions
Do you have a comment about the ethics of this?
It may be that you are, in fact, dealing with bones, in isolation.
So far I was thinking that 200 µT field foe 1 hr/ day should not make any discomfort to the animal.
Actually this information is currently for a grant application and I need to check this with the other department for the ethics about applying EM field in the animals.
Mit
I agree. What bothers me is breaking the animals' bones in the first place. Crack - squeak! Never mind - you'll soon be mended again.
But your grant application will obviously be vetted for any such problem (if you are in a civilised part of the World.)
But, returning to the EE aspect, you will need to have the parameters of the coil (which will be on record somewhere) and then come back for some ideas about the power requirements. At some stage, you will need to be getting your hands dirty with beastly electrical stuff. You will need to be measuring the current in the coil circuit and that will involve breaking into the wire and inserting an Ammeter (AC) Most DMMs can measure current up into audio frequencies.
60Hz is way more convenient than any other frequency you might choose. (other than 50Hz in Europe etc)
I would imagine that your grant application will need to involve fairly good estimates of fields and frequencies, based on earlier work. You could expect that, in any interview, you could be asked to provide some 'Engineering' figures. The easiest aspect of the work would be producing a source of variable frequency AC at a few Watts. That's Radio Ham stuff. and probably off the shelf in your lab, somewhere. Finding out what you actually want will be the hardest technical task.
Hi,
Thanks.
I can understand your feeling for animals (regardless you are vegeterian or nonveg) however I am sure that you completely ignore the fact that if this method works, how much releif it can bring to older patients having factures where bone just refuse to heal and making life of the older patients miserable. You may also want to know how many animals were killed to find the vaccines which brings comfort to our life.Never mind this is not the right discussion for the forum.
Being from the civilized contry (I think) called Germany, I am sure that I need to give a clear picture about the application I am making. I really appreciate the doubts you raised as it helped me to think more about the physics aspect of this project.
Rearding the coil parameters, the coils have inductance of (1.5 mH) and current flowing through should be 15 Ampere. Yes now I am thinking on variable AC frequency generator.
I would think that by now in most developed countries, there are protocols in place for medical experiments involving lab animals. After all, as Centaur points out, you need to break the bone before you can try to heal it. It does sound like you are following protocols.
Then you will definitely need a power amplifier. If you are doing a grant proposal, include the AFG and a power amp in your equipment list that you need to purchase.
Hmm. That's a philosophical issue as to whether the means always justify the end. It's beyond my pay grade to decide what 'should' be done in cases like this. There are plenty of dodgy procedures using animals and they are sometimes have flimsy justification. I fully understand your feelings about this, though. You will need to abide what the 'committee' decide if you want to avoid disciplinary issues, though.
Germany is pretty squeaky clean in this regard, I think.
Thanks for suggestions..
I do not see the justification for animal experiments because 200uT seems to be essentially safe for humans, and is the Reference Level for low frequency magnetic fields. So why resort to animal testing?
Interesting question. So you are saying, if that level of EM is definitely safe for humans, why not bypass animal testing and go straight to double-blind human testing?
I think that's a good question. @mit_cool -- would you consider modifying your proposal?
May I mention that the international safety recommendations for exposure to electromagnetic fields may be found at the URL below. The secretariat of the ICNIRP is based in Germany:-
http://www.icnirp.org/cms/upload/publications/ICNIRPemfgdl.pdf
As a matter of interest, this has been around a long time, and I was aware of the apparently beneficial effects of EM fields on bone healing some 20 years ago, having read papers on the subject. I actually enquired about its use when a family member suffered a severe fracture at that time, but it was not available.
Unfortunately, that would involve ramping up the scale and cost of the project. Probably too much for a PhD project, unless the establishment was already involved with that sort of study. You'd need agreement with all the subjects and a highly qualified radiologist to help you assess the effects on their healing process.
I would reckon that the most feasible solution could be at the Petri Dish level using, say, crushed fresh chicken bones in a suitable nutrient solution. The ethical considerations would be dealt with by the slaughterers of the chickens (and they have very lax regulations).
I just realized that this topic is not a million miles away from the magnetic limescale reduction systems that are available and which cause such a lot of controversy.
Thank you guys, we will consider contacting ICNIR.. We are now in contact with animal committee of our university and trying to find their suggestion for optimal parameter of EM field.
@Berkemann: that is nearly impossible to check anything directly on the patients bypassing the animals. The main idea of our research is to accelerate the healing (dont confuse it with 'start the healing') specially in older patients when bone heals very slowly. For this we are using combination of Electrical stimulation and tissue engineering where we put the stem cells at the fractured region and stimulate them electrically using an implant. And we already have positive results in animals. But this procedure required surgery in order to reduce the surgical complications to animals ( and ultimately to the patients) we want to use coils to generate helmholtz effect in the stemcells at the fractured region.
Hope this make sense
It would be outside the scope of a PhD project, true but there have been many such equivalent tests on this and other conditions. Have they all involved animal testing?
There are a lot of procedures on and,als that I, certainly, wouldn't want to be part of - although, of course, I wouldn't know when I may have benefitted from them. But that's what ethics committees are supposed to take care of. They let us rest easy about such nagging worries.
