How can I accurately calculate the area between two curves?
  • Thread starter Thread starter Procrastinate
    Area Curves
6 replies · 3K views
Procrastinate
I am having trouble with this question: (QUESTION AS ATTACHED)
This is what I tried to do:
I found the intercepts of the difference of the two functions which I found to be only 8.
Then I integrated this into the new function:
[tex]\int{\sqrt{2x}-x+4}[/tex]. with limits of 0 and 8 (I don't know how to Latex this)
This, according to my Graphics Calculator yielded 21.3.
However, the answer is 18, what have I done wrong?
Edit: [tex]\int_0^8 (\sqrt{2x} -x + 4)\,dx[/tex]
First, find where the line intersects the curve.
Then from the points of intersection, draw a horizontal line to the y-axis, what shape is formed with the straight line and these two new lines you just drew? What is the area of this shape?
EDIT:
I see what you are doing now. Your way will be the same, you will need to subtract the same amount of times.
Click on my LaTeX output image below to find out:
[tex]\int_0^8 (\sqrt{2x} -x + 4)\,dx[/tex]​
rock.freak667 said:
Then from the points of intersection, draw a horizontal line to the y-axis.
I am not sure what you mean here, but is the answer a triangle?
Yep. You can get the area of the triangle. You can get the area of the region bounded by the curve and the y-axis and then subtract.
I think that this would work best as a double integral. Your y-limits are between 2 and 8 and your x-limits are between y^{2}=2x and y=x-4, this will give you the correct answer.
Mat
It is easier to calculate the area enclosed by the lines of the inverse functions, x=y+4 and x=y^2/2.
ehild
