How can I analyze this transimpedance amplifier?
13 replies · 3K views
Boltzman Oscillation
The opAmp network shown in figure 68 is a transimpedance amplifer that employs both negative and positive feedback. Assuming that the op-amp is ideal, calculate the value for the output voltage for Jg is 1mA.The circuit and question are this:
https://www.chegg.com/homework-help/questions-and-answers/84-op-amp-network-shown-figure-84-transimpedance-amplifier-employs-negative-positive-feedb-q31684479
Vp = Vn
In = Ip = 0
KCL
KVL
I tried using KCL to make the following
(Vn - Vj)/R1 + (Vn-Vo)/R2 = 0
(Vn - Vj)/ R3 + Vn/R5 + (Vn - Vo)/R4 = 0
but I really don't think this is the way to solve the problem. I don't really know the voltage across the current source so it's pretty useless for me to use it here. Can anyone guide me to the right direction? Does anyone know a good resource to read on op amps?
I think you used KCL correctly.. Finding the current through Jg is easier than you think it is.
You mean the voltage? I am given the current of Jg to be 1mA but not the voltage across Jg (which is what i need if I were to use KCL.
What can you say about the current through ##R_2##? Can you find an expression relating ##V_o## and the potential at the op-amp inputs?
It certainly appears you are trying to use the fact that the total current into the node at the negative input of the op-amp must be 0 when you write
(Vn - Vj)/R1 + (Vn-Vo)/R2 = 0. It's Kirchhof's Current law, you know what the current is through R1.
Trick Question. What is the difference between a current source, and the same current source in series with a 5k resistor?
I don't know? A current source in series with a resistor can be transformed to a voltage sorce with a resistance in parallel.
Yes i can do that and I've actually done it in my notes but i will still end up with a variable for the voltage of Jg in my equation. Do i not have to take that out somehow?
Nope. You can transform a voltage source with a series resistance into a current source with a parallel resistance. And you can transform a current source with a parallel resistance into a voltage source with a series resistance. But you cannot transorm a current source with a series resistance into anything that doesn't look like a current source. Same goes for a voltage source in parallel with a resistor.
Think about it. If you place a resistor across a voltage source V, what voltage will you measure across the source? Can any resistor value change it?
Now think about the current source with a series resistor...
You'r doing KCL and so summing currents. What current is coming from Jg?
Oh so one of my equations should be:
-Jg + In + Ir2 = 0
this is because the current through R1 is the same as the current source? This would give me:
-Jg + (Vn - Vo)/R2 = 0 (1)
(Vn - V3)/R3 + Vn/R5 + (Vn - Vo)/R4 (2)
I can then transform equation one to:
-Jg/R2 + Vn/R2 = Vo (3)
Which can be plugged into (2)? Am I doing this right?
-Jg + In + Ir2 = 0
Yes. No matter what resistance is placed in the path of an ideal current source, the same current flows.
This would give me:
I don't see where V3 comes from. When you do KCL at the bottom node, what current is Jg pulling from that node?
Sorry I misread my solution.
I believe the current across R3 should be Jg right? So equation 2 should become:
Jg + Vn/R5 + (Vn -Vo)/R4 = 0
I understand now, a resistance in series with a current source will have a current value of that current source. I can look at this by visualizing the ideal current source.
Okay i think I have the right tools to complete this question. Thank you all.
