How can I build a simple Wells Turbine for my OWC wave power plant model?
  • Thread starter Thread starter shinizaki
    Device Turbine
A student studying Ocean Engineering is seeking guidance on constructing a Wells turbine for a wave power plant model based on Oscillating Water Column (OWC) technology. They are looking for diagrams and recommendations due to limited experience in electrical engineering. The discussion focuses on the design and construction of a simple Wells turbine suitable for their project. Participants are encouraged to share resources or advice to assist in the turbine's development. Overall, the inquiry highlights the need for accessible information on turbine design for renewable energy applications.
shinizaki
Hi everyone,
I am student of Ocean Engineering and now I am in process designing a model of wave power plant based on OWC. For that, I need Wells turbine for generator. I don't have many experiences in electricity engineering so do anyone have diagram to build simple Wells Turbine ? Thanks before.
Is there any recommendation how to built it ?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
