How can I calculate the average power from a driving cycle using Matlab?
  • Thread starter Thread starter pchoopanya
    Integration Matlab
7 replies · 5K views
pchoopanya
Hello,
I need to work out the average load power which is expressed by the equation attached;
I am not sure about how I can do this, I am so dumb at calculus.
M, g, fr, [tex]\rho[/tex], CD, Af, [tex]\delta[/tex] and T are one single constant
However, V which stands for velocity varies with time, T or t and its values are formed into a matrix
How can I perform this finite integration? Which command do I need?
Or, shall I just plot the graph of power, P against time, t and use the command, like trap to find the area under the curve since I have an array of V against t (V cannot be expressed as a function of t)
I think I am lost as I have not touched calculus for very long long time.
Thank you for your help guys.
pchoopanya said:
Hello,
I don't think your equation attachment worked. Could you please try again?
Hi,
thank you for telling me
Here again.
I will show you the power plot against time
As you can see the power curve does not have a pattern at all
My apology,
I have re-arranged my questions so that you guys can see more easily what actually I am trying to do;
Please see the attached picture;
These are 4 examples of 4 different drive cycles (vehicle speed VS time)
From that, using simple longitudinal linear dynamic equation, I then obtained a plot of tractive force against time. Finally, to convert force into power, simply multiply by a velocity.
Note that, only the data of velocity at each time interval is known (as a metrix)
However, I also need to know what the average power is, in order to properly size the engine/fuel cell, I have been given the above equation which involves integration.
My question is, how can I obtain the average power as shown in the picture?
Thank you very much again.
pchoopanya said:
My apology,
Thank you for the extra details. But of course power cannot be negative in the context of this question. How should you modify your calculations so far to fix this?
Unless you are using some regenerative braking recovery of energy in your calculations -- apologies that it is not clear to me.
Morning from UK berkeman,
Well, the reason why the power is negative comes from the attached equation,
By knowing a specific driving cycle (velocity profile against time), in this case, I'm using a Bangkok drive cycle (Thailand), the remaining variables are already known, I could then work out the Tractive Force required at wheel in order for the vehicle to follow the drive pattern.
Where Ft = Tractive effort (N)
M = Bus mass (18000 kg)
g = gravitational accel. (9.81 m/s^2)
f r = rolling resistance coefficient (0.015)
[tex]\alpha[/tex] = road gradient (0 degree, flat road)
[tex]\rho[/tex]a = air density (1.146 kg/m^3 at 35 C in Bangkok)
CD = Drag coefficient (0.8)
Af = frontal area (7.8 m^2)
V = vehicle speed (m/s)
[tex]\delta[/tex] = mass factor due to rotating components, such as gears, wheels etc. (1.035)
t = time in seconds
The first term of the right hand side = tractive effort to overcome rolling resistance
The second term of the right hand side = tractive effort to overcome aerodynamic resistance
The third term of the right hand side = tractive effort to accelerate the vehicle mass
The spreedsheet is also attached to show the calculation together with the graphs, you can see that I did not include any Re-gen brake ability, but I believe the negative power is just a result from the negative values of the third term on the right hand side (effort to accelerate the mass), which is a result of negative dV/dt
I do not quite understand what this actually means by the NEGATIVE power in some parts of the plot. How can power be negative? Can anyone help? please.
Most important, how can I find the AVERAGE power from this? So that I could determine the appropriate size of engine/fuel cell. If this is to use the above integral equation, how can I do this?
Thank you very much
  • BDC.zip
    BDC.zip
