How can I calculate the tension force?
5 replies · 2K views
elleo
Find the tension force that the rope is doing to the bridge (see attached image)
T=mg
I don´t know if others apply
This is my attemp of solution:
Since the formula to calculate the tension is T=mg
I first calcualted the weight of the bridge with the ecuation
W= mg m=W/g
m= 18,000 N / 9.81 m/s
m= 1834 kg
So T=(1834)(9.81)= 17,991 N
But this seems no logical to me because the Tension force is a bit less than the weight force of the bridge, I think it should de more
That would only be for the simple case of a mass hanging statically and vertically, with no other support for the mass.
The diagram is unclear without more explanation. Is it a uniform load of 3kN/m (in which case, the arrows are showing torque about the joint)?
There is a standard procedure for solving just about any 2D mechanics problem:
- pick a rigid component;
- consider the sum of forces and resulting acceleration (ΣF=ma) in each of two directions, usually at right angles;
- pick an axis and consider the sum of torques and resulting acceleration (Στ=Iα) about the axis.
Since this is a statics question, a=α=0.
Yes, it’s a uniform 3 KN/m
And the diagram doesn’t give the angle between the bridge and the wall, so I don’t know if it’s possible to calculate the resulting force
Pretty sure you should assume that the angle between the bridge and wall is 90°. If in doubt, specify your assumption in your submitted answer. If the problem statement leaves out critical information, it's your choice to specify your assumptions. Markers can't (well, shouldn't) penalize for missing information.
Please submit the entire actual problem statement. Arrows in that form generally means a linearly increasing load, not a uniform load unless what is shown is the resulting torque at each point (which would be incompatible with the 3 kN/m quoted at the end).
m= 1834 kg
Don't you see that you've just gone in a circle? You took 18 000 N, divided it by ##g##, and then multiplied the result by ##g##. Apart from the round-off error, you end up with exactly what you started with, 18 000 N.
Can you draw a free-body diagram of the beam and then use the 1st and 2nd conditions for equilibrium to set up your equations? Hint, ##T=mg## will not be one of those equations. And your intuition that ##T## should be greater than the magnitude of the weight force is correct. Note that the magnitude of the weight force is ##mg##.
