How can I calculate wall thickness for vacuum distillation?
This discussion focuses on calculating the wall thickness for two industrial vacuum distillation systems designed by an organic chemistry expert. The tanks are made of Black Iron Sheet, with dimensions of 200 cm length and 200 cm diameter for the first tank, and 400 cm length and 290 cm diameter for the second tank. Operating conditions include a pressure range of 0.1-0.07 mbar and temperatures between 200-350 degrees Celsius. The recommended method for determining wall thickness is to use the formula t = PD/2S, while also considering applicable ASME Boiler and Pressure Vessel Codes for safety compliance.
  • Understanding of ASME Boiler and Pressure Vessel Codes
  • Knowledge of material properties, specifically for Black Iron Sheet
  • Familiarity with pressure and temperature effects on material stress
  • Basic engineering principles related to tank design
  • Research the ASME Boiler and Pressure Vessel Codes relevant to vacuum distillation
  • Learn about material stress calculations for Black Iron Sheet at high temperatures
  • Investigate engineering design principles for industrial distillation systems
  • Consult with a mechanical engineer specializing in pressure vessel design
Mechanical engineers, chemical engineers, industrial designers, and anyone involved in the design and safety assessment of vacuum distillation systems.
saidi_farzad
Hi everybody,
I want to design two industrial vacuum distillation systems.
The dimension of my distillation tanks are as follow:
(1) A Horizontal Cylinder Tank with 200 cm length and 200cm diameter (total volume = 6300 liter)
(2) A Horizontal Cylinder Tank with 400 cm length and 290cm diameter (total volume = 26500 liter)
The material for both systems is Black Iron Sheet. The pressure and the temperature I want to work at are in the range of 0.1-0.07 mbar and 200-350 degree of centigrade.
But I don’t know what wall thickness for the distillation systems is safe?
By the way, I am an organic chemistry expert, so I don’t know much about design of distillation systems (which is an engineering problem).
A basic method would be to find your allowable stress based on your material and temperature, the pressure of the fluid and the outer diameter of your tank and apply the formula:
t = \frac{PD}{2S}
However if you can, you can use applicable ASME Boiler and pressure vessel codes.
saidi_farzad said:
Hi everybody,
Since your field of expertise is organic chemistry, it would be wise to consult a mechanical engineer to assist you with this project.
Since this is intended to be industrial equipment, I'm surprised there isn't an engineer involved in this project already. :))
10K
10K
