How Can I Convert a Nested For Loop to a Do-While Loop in C++?
magnifik
I am trying to create a code that does the exact same thing as this does
Code:
#include <iostream>
	using namespace std;
	int main()
	    int len;
	    cout << "Enter a number: ";
	    cin >> len;
	    for (int i = 0; i < len; i++)
		for (int j = i+1; j < len; j++)
		    cout << ' ';
		cout << "#\n";
but using a do while loop instead. what i have so far is this
Code:
#include <iostream>
	int main()
	    int len;
	    cin >> len;
			int j = i+1;
			do
				cout << ' ';
				j++;
		while (j < len);
		cout << "#\n";
the only problem is on the last line the "#" signs line up instead of being diagonal. any help on how to fix this??
try put a if condition insdie the do while loop instead just count outside while loop. could use conditions like if j = len -1, then count the #
kentigens said:
try put a if condition insdie the do while loop instead just cout outside while loop. could use conditions like if j = len -1, then cout the #
hmm, not exactly sure what you mean. the closest i got was adding
Code:
 if (j == len -1) {
           cout << "#";
into the do part of the do while loop, but this just created two side by side diagonal lines :T to top line had len - 1, but the bottom line had the correct shape and number. any idea on how to get rid of the first one?
i mean to take out the line where u count the # from ur original code. and btw, don't have vs here, so can't really run ur code. can u please post up the outputs? both original code and the one u have atm?
