How can I diagonalize matrices A and B to solve the matrix exponential problem?
12 replies · 3K views
JamesGoh
Given matrix A= [1,1;0,0] and matrix B = [1,-1;0,0]
n.b. the semicolon separates the matrix rows
find exp(A)exp(B)
[itex]exp^{A}=\sum\frac{A^{n}}{n!}=I + A + \frac{A^{2}}{2} + \frac{A^{3}}{6} + ... + \frac{A^{n}}{n!}[/itex]
for n= 0 to infinity
The answer the tutor give is the following matrix
exp(A).exp(B) = [e^2,-(e-1)^2 ; 0,1]
this would imply that A and B are diagonalisable (since they need to be in order to get the form of the answer)
However, if I worked out the characteristic ppolynomial of A and B, I would only get one eigenvalue, not two distinct eigenvalues which rules out any chance of diagaonlisation
Is there a way to diagaonlise A and B ?
find exp(A)exp(B)
I get two eigenvalues for each matrix, so I don't know what you did that you came up with only one apiece.
You can also do this problem without diagonalizing either matrix. Use your relevant equation, which should be slightly amended. It's not a finite sum.
[tex]exp^{A}=\sum\frac{A^{n}}{n!}=I + A + \frac{A^{2}}{2} + \frac{A^{3}}{6} + ... + \frac{A^{n}}{n!} + ...[/tex]
A standard result for an nxn matrix with all eigenvalues different is: if r_1, r_2,...,r_n are the eigenvalues, there exist matrices E_1,E_2,...,E_n such that for any analytic function f(x) = sum c_n x^n (with radius of convergence containing all the r_j) then f(A) = c_0*I + c_1*A + c_2*A^2 + ... = sum_j f(r_j)* E_j . Here the E_j are the same for any f, so cn be found, for example, by looking at f(x) = 1 = x^0, f(x) = x, f(x) = x^2, etc. Having the E_j, now use f(x) = exp(x) to get exp(A).
For a 2x2 matrix with eigenvalues 'a' and 'b' we have I = E1 + E2, which comes from using f(x) = 1. Similarly, A = a*E1 + b*E2 (using f(x) = x).
RGV
What was your characteristic polynomial for A ? What eigenvalues did you get for A ?
Also, what char. polynomial and eigenvalues did you get for B ?
Those are both "Jordan form" matrices so the numbers on the diagonal are the eigenvalues.
What did you get?
vela said:
What did you get?
I got 0 and 1 as the eigenvalues for both matrix A and Matrix B.
The characteristic polynomial I got for A was [itex]λ^{2}-λ[/itex]
Similary, my char. polynomial for B is [itex]λ^{2}-λ[/itex]
So you got two distinct eigenvalues, and you can diagonalize them both.
As Mark mentioned, you can calculate eA and eB without diagonalizing though. A matrix satisfies its characteristic polynomial, so A2-A=0. Using that fact, you can easily simplify the series.
Thanks for that. I was asking in the first placecause I knew the diagonal form of both A and B would be
[ 0, 1 ; 0, 0]
which is nowhere close to the tutor's answer
That's not the diagonal form of either A or B.
Also, your tutor calculated exp(A)exp(B), which isn't the diagonalization of A or B.
but doesn't the Diagonal matrix contain the eigenvalues down the main diagonal and 0's elsewhere ?
what don't I understand ?
The matrix you wrote was
\begin{pmatrix} 0 & 1 \\ 0 & 0 \end{pmatrix}which isn't diagonal.
