How Can I Display Each Digit of a Four-Digit Integer on a Separate Line in Java?
  • Topic: Java
  • Thread starter Thread starter J.live
    Java Method String
3 replies · 7K views
J.live
Write a program that reads four-digit integer as a string , such as 1998 and then displays it, one digit per line, like so:
Attempt:
Scanner keyboard2 = new Scanner (System.in);
String integer2= "Input a 4 digit number:";
System.out.println(integer2);
How do I make it read ? How do I go about this using string method ? I am lost. Thanks
huh...never seen the Scanner class before. Here's the first doc page I found:
http://www.cs.utexas.edu/users/ndale/Scanner.html
Looks like you can call Scanner.next() to get a string from stdin.
Then you could use String.charAt( x ) to get each character for printing. See here:
http://download.oracle.com/javase/1.4.2/docs/api/java/lang/String.html
For extra credit I guess you could do error checking and stuff to make sure you always get a four digit number as input.
How do I implement digits into the split characters ?
Like I type in any four digit number and prints it in a vertical fashion.
Never mind , I got it.
Your integer2 variable is a string instance, which is essentially an array of type char. You can use the charAt method on the string class to get the character at the specified index.
For instance, if integer2 contains the characters '2', '0', '1', and '1', the expression integer2.charAt(2) evaluates to the character value '1'.
You can use a loop to peel off each character in your integer2 variable.
