How can I do when I make a Log2 towards zero?
9 replies · 2K views · last reply
munirah
Good day,
I want to make a measurement on qubit by using formula von Neumann entropy using Mathematica given as below;
(ρ)=−Tr(ρlog2ρ)
The
ρ={{0.5,0},{0,0.5}}My problem is, when I make the
log2{{0.5,0},{0,0.5}}
I get the output
{{−1,∞},{∞,−1}}
How can I deal with this value in my measurement since it cannot be calculated?
Thank you.
Can you put in some lower limit, like ##2^{-20} ## ?
[edit] Ha ! o:)
[edit2] Isn't it so that you have already diagonalized ##\rho## so you can use the ## S = - \sum \eta\ln\eta ## here ?
mfb said:
Looks like you take the logarithm of each entry in the matrix. I don't think that is what you want.
Matrix log?
I'm not sure about the matrix log.I think it different
[edit] Ha ! o:)
thank you for the input. I will search it and learn
My guess is the matrix log coincides with taking log of the diagonal elements once the matrix is diagonalized ...
it means only for diagonal matrices?
BvU said:
Just a guess. :smile:
ok. thank you very much. i will look about it.
Sure. This should be easy to see if you take the matrix exponential again.
