How can I efficiently capitalize items in a list without modifying the original?
  • Thread starter Thread starter zeion
    Beginner Python
10 replies · 3K views
zeion
I'm supposed to write a function that does this:
def capitalize_items_2(lst):
Return a new list with the same items as lst, only in upper case. lst is a list of strings. This function does not change lst
lst2=[]
i=0
for x in lst:
lst2.append(lst.upper())
i+=1
return lst2
But how come I can't define lst2 inside the function and return it?
Do I need to define it outside or is there a better way?
Thanks.
My Python knowledge is very limited, but I hope I can help.
If you are unable to return a list defined within a function, then you are conflicting with the scope of variables inside of functions. What is the lifetime of lst2 in the function? That is, do local variables to the function 'die' when the function ends? If so, then you can't return a variable that no longer exists.
You may want to look into list comprehensions at http://docs.python.org/tutorial/datastructures.html
or the map function.
zeion said:
Code:
    lst2=[]
    i=0
    for x in lst:
        lst2.append(lst[i].upper())
        i+=1
    return lst2
I was able to successfully run your code. (There's also some things you can do to optimize your code.)
Weird..
I tried to actually test it on a list like this:
i=0
lst2=[]
for x in lst:
i+=1
return lst2
lst = ["fs", "trt", "fdscv"]
print lst2
I get this:
Traceback (most recent call last):
File "C:\Documents and Settings\Truman\Desktop\cap2", line 12, in <module>
print lst2
NameError: name 'lst2' is not defined
It works if I define lst2 outside the def though.
Does it matter what version I'm using?
How do you call the function? You need to store the returned value in a variable, like this:
Code:
outputList = capitalize_items_2(inputList)
where inputList is the function input and outputList stores the result of the function.
zeion said:
Weird..
Code:
    i=0
    lst2=[]
    for x in lst:
        i+=1
    return lst2
print lst2
Try:
Code:
    i=0
    lst2=[]
    for x in lst:
        i+=1
    return lst2
lst2 = capitalize_items_2(lst)
print(lst2) # I'm using print as a function for forwards compatibility with Python 3
Ooh I see now.. so I actually need to assign the function to something
Also, FYI, list types have a method called index, which will return the index of the item. So, you could just write:
Code:
def capitalizeItems3(lst):
    lst2 = []
    for item in lst:
        lst2.append(lst[lst.index(item)].upper())
    return lst2
Glad to help.
Code:
    for item in lst:
        lst[lst.index(item)] = lst[lst.index(item)].upper()
    return lst
Glad to help.
Oh that's good haha.
Seems like I always code things inefficiently :/
My example actually would replace the original list; I've fixed it above. Sorry, it's late here.
Practice. No one ever wrote great code when they first started learning. :smile:
