How can I evaluate this double integral?
  • Thread starter Thread starter _N3WTON_
    Integrals
7 replies · 2K views
_N3WTON_
Evaluate the following double integral:
[itex]V = \int\int \frac{3y}{6x^{5}+1} \,dA[/itex]
[itex]D = [(x,y) \hspace{1 mm}|\hspace{1 mm} 0<=x<=1 \hspace{5 mm} 0<=y<=x^2][/itex]
[itex]V = \int_{0}^{1} \int_{0}^{x^2} \frac{3y}{6x^{5}+1}\,dy\,dx[/itex]
[itex]= \frac{1}{2}\int_{0}^{1}\int_{0}^{x^2}\frac{y}{x^{5}+1}\,dy\,dx[/itex]
[itex]= \frac{1}{2}\int_{0}^{1}\int_{0}^{x^2}\frac{y^2}{2x^{5}+1}\,dx[/itex]
[itex]= \frac{1}{2}\int_{0}^{1}\frac{x^{4}}{2x^{5}+1}\,dx[/itex]
[itex]= \frac{1}{4}\int_{0}^{1}\frac{x^{4}}{x^{5}+1}\,dx[/itex]
To integrate, I made the following substitution:
[itex]u=x^{5}+1[/itex]
[itex]du=5x^4[/itex]
Therefore, the new limits for integration are:
[itex]u=1[/itex]
[itex]u=2[/itex]
[itex]= \frac{1}{20}\int_{1}^{2}\frac{du}{u}[/itex]
[itex]= \frac{1}{20}[lnu][/itex]
[itex]= \frac{1}{20}[ln2-ln1][/itex]
This is my final (incorrect) answer:
[itex]\frac{ln2}{20}[/itex]
Obviously, I am making a mistake somewhere, but I can't see where so I thought a second (or third) set of eyes may help :) Thanks
You need to learn how to use parentheses so that your algebra is correct:
[itex]\frac{y^2}{2x^{5}+1}[/itex] should be [itex]\frac{y^2}{2(x^{5}+1)}[/itex] after you integrate
[itex]u=1[/itex]
[itex]u=2[/itex]
ok, so then the answer will turn out to be:
[itex]\frac{ln7}{20}[/itex]
no?
thanks for the help :)
Sorry I always forget to show my solution:
[itex]V = \int_{0}^{1} \frac{3}{6x^{5}+1}\frac{y^2}{2}\,dx[/itex]
[itex]= \frac{3}{2}\int_{0}^{1}\frac{x^4}{6x^{5}+1}\,dx[/itex]
[itex]u = 6x^{5}+1 \hspace{5 mm} du = 30x^4[/itex]
[itex]{when} \hspace{3 mm}x=0, \hspace{3 mm} u = 1[/itex]
[itex]{when}\hspace{3 mm} x=1, \hspace{3 mm} u = 7[/itex]
[itex]= \frac{1}{20}\int_{1}^{7}\frac{du}{u}[/itex]
[itex]= \frac{ln(7)}{20}[/itex]
no?
Seems ok to me.
Dick said:
Seems ok to me.
thank you
Your final answer is correct but [itex]du= 30x^4 dx[/itex] so [itex](1/30)du= x^4 dx[/itex]
