How can I factorize this function into A(a) and X(x)?
  • Level: Graduate
  • Thread starter Thread starter picard
    Function
8 replies · 2K views · last reply
picard
Hi,
I need some help factorizing the following:
[tex]\frac{g(x)-g(a)}{u(a)^2}=K(x,a)[/tex]
into [tex]A(a) X(x)[/tex]
ie I want to find [tex]A(a), X(x)[/tex] such that their product is the first equation. The reason I want to do this is because K(x,a) is a kernel and it would help a lot if somehow I could write it as:
[tex]K(x,a)=A(a) X(x)[/tex]
Finally, note that [tex]g'(a)=a/u(a)^2[/tex]
Any ideas?
Thanks in advance
Mathematics news on Phys.org
Well, that was my first guess as well, but I thought that someone might have an idea...
Kernel in an integral equation? While that is not separable, you can write it as a sum of separable terms:
[tex]\frac{g(x)}{u(a)^2}- \frac{g(a)}{u(a)^2}[/tex]
and work with each part separately.
Yes, I have tried that. However, then the integral equation is not solvable, while if the kernel can be written with only one term as K(x,a)=A(a) X(x) then there exists an analytical solution...
I assume, then, that you are talking about a Fredholm integral equation:
[tex]y(x)= \inf_a^b K(x,t)y(t)dt+ f(t)[/itex]<br /> <br /> Yes, if K(x,t) is "separable", K(x,t)= A(x)B(t), then the solution is easy. The equation becomes<br /> [tex]y(x)= A(x)\int_a^b B(t)y(t)dt+ f(x)[/itex]<br /> and <br /> [tex]\int_a^b B(t)y(t)dt[/tex]<br /> is a number. Let <br /> [tex]X= \int_a^b B(t)y(t)dt[/tex]<br /> and you have y(x)= X A(x)+ f(x) so it is just a matter of solving for X. Multiply both sides of that equation by B(x) and integrate from a to b.<br /> [tex]\int_a^b B(x)y(x)dx= X\int_a^b A(x)B(x)dx+ \int_a^b B(x)F(x)dx[/tex]<br /> The integral on the left is just X again and the other two integrals are of known functions. Let <br /> [tex]K= \int_a^b A(x)B(x)dx[/tex]<br /> and <br /> [tex]F= \int_a^b B(x)f(x)dx[/tex]<br /> and X satisfies the equation X= KX+ F which is easily solvable for X.<br /> <br /> Now, suppose K(x,t) is not separable but is the sum of two separable functions: K(x,t)= A1(x)B1(t)+ A2(x)B2(t). we can still take the "x" dependence out of the equations:<br /> [tex]y(x)= A1(x)\int_a^b B1(t)y(t)dt+ A2(x)\int_a^b B2(t)y(t)dt+ f(x)[/tex]<br /> Let<br /> [tex]X1= \int_a^b B1(t)y(t)dt[/tex]<br /> and<br /> [tex]X2= \int_a^b B2(t)y(t)dt[/tex]<br /> Now,<br /> [tex]y(t)= X1A1(x)+ X2A2(x)+ f(x)[/itex]<br /> and we only need to find the numbers X1 and X2.<br /> If we multiply that equation by B1(x) and integrate:<br /> [tex]\int_a^b B1(x)y(x)dx= X1\int_a^b A1(x)B1(x)dx+ X2\int_a^b A2(x)B1(x)dx+ \int_a^b B1(x)f(x)dx[/itex]<br /> Again, the left side is just X1 and the integrals on the right are numbers:<br /> [tex]X1= K_{11}X1+ K_{12}X2+ F1[/tex]<br /> with the obvious notation. Doing the same with B2(x), <br /> [tex]X2= K_{12}X1+ K_{22}X2+ F2[/tex]<br /> <br /> That is, we have two linear equations to solve for X1 and X2. (And, in fact, the system is symmetric, guarenteeing real solutions.)<br /> <br /> The extension to any kernel which is a finite sum of separable functions should be obvious and, in fact, it can be extended to an infinite sum of such functions, giving an infinite series solution.[/tex][/tex][/tex][/tex]
@HallsofIvy: Thanks for taking the time and effort to write your answer! I really appreciate it. However, you assumed erroneously... My integral equation is a Voltera of the second kind... The thing is that for a seperable kernel with one term (like the one I am looking for) the solution is readily available, see for example:
http://eqworld.ipmnet.ru/en/solutions/ie/ie0214.pdf
However, if K(x,t) is not separable but is the sum of two separable functions then you have to solve a system of ODEs instead of an algebric (simultaneous) system... In my case the system with the ODEs is quite complicated and that's why I decided to ask if somebody knew of a way to factorize my kernel (so that I could use the analytical solution of the link).
Again, thanks and sorry...
picard said:
Hi,
(I'm assuming that g is known not to be a constant function)
A(0) X(0) = 0
A(0) X(x) = (g(x) - g(0)) / u(0)^2 which is nonzero
Therefore, A(0) is nonzero, and so X(0) = 0.
0 = A(x) X(0) = (g(0) - g(x)) / u(x)^2
Therefore, g(0) = g(x) for all x, which contradicts the fact g is nonconstant
Therefore, K(x,a) cannot be written as A(a) X(x).
@Hurkyl: Thanks, at least I now know that there is no solution to this problem and I can move on.
Cheers
