How can I identify the molecular fomula, based on an m/z of 350.7897?
  • Thread starter Thread starter bellum
    Mass Molecule
To identify the molecular formula based on an m/z of 350.7897, utilize tools like www.chemcalc.org to explore potential structures. Analyze the mass spectrum, focusing on the highest mass ion and the differences between peaks to deduce possible atom groups. Consider the nitrogen rule and fragmentation patterns to align with the other m/z values. Repeat this process for various fragment losses to construct the molecular structure. This systematic approach will help clarify the molecular formula.
bellum
Thread moved from the technical forums to the schoolwork forums
TL;DR Summary: I have the aforementioned m/z and a mass spec graph, my lecturer completely glossed over how to find the molecular formula so I'm stumped.
I have a mass spec with 4 peaks and the m/z value, how can I find the molecular formula.
Maybe this can help you
You have a very exact mass. Use www.chemcalc.org to find possible structures. Remember the nitrogen rule. Deduce possible structures and look if their fragmentation patterns fit the other m/z tops.
What do you think the highest mass ion represents (in most examples for students to solve, that is).
What do you think the difference between two peaks represents?
What group of atoms could that be?
Repeat for several of the fragment losses.
Build the molecule.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
